Looking for leveling kit, which way to go?
on
A better kit will have radius arm drop brackets and track bar drop brackets or a replacement track bar. Anytime you change geometry you're going to have to make up for it in all the parts, otherwise it won't align properly.
I cheaped out, got a level kit and ended up redoing it all weeks later with a proper lift kit because I wasn't completely satisfied. There's time and money right there.
I have been back and forth with this over the last month or so. I think I have finally decided to go with the Carli leveling kit. I'm not going with the full blown pin top right now. Starting off with the base kit. I like the fact that I can build off of it and that it comes with quite a few nice components for a decent price even with the base kit.
FWIW, the previous owner of my 250 put a "leveling kit" on the front, and to me, it seemed, it gave the truck a reverse rake, the front was higher than the rear. I ended up purchasing some 350 blocks to lift the rear end to level it back out. The two other stock '11 250's we have here in the fleet seem to backup my eyeballs, those trucks sit level to me, from the factory.....
From my understanding, it's the 350's that are higher in the rear (4" block vs. 2" block) and they are the trucks that benefit the most from the "leveling kit".
You may find yourself in my situation, and in that case, I'd say just look into a full kit right off the bat. Once I put the taller rear blocks on, the headlights were back to useful and I felt the steering feedback increase. I'm just guessing that reverse rake somehow kinda lightened the front axle.
A leveling kit needs to have 350 blocks in the rear to sit "level".
If you are leveling, I personally would replace the springs/shocks and the track bar. The track bar is typically the source of death wobble anyway, so good to replace it with a HD unit anyway.
You can use the replacement caster bushes if you are looking to save money instead of new radius arms/drop brackets, and it will get you close to stock alignment specs.
If you have a 250, the only way the truck will be "level" is if you lift the front and the rear the same amount. The 250 sits nearly level already. I see a 2011 F250 with a "leveling kit" every day and can't figure out why he wants to ride around with the nose in the air like that.
As for the best leveling method, everybody has different tastes and budgets. I have used a 2.5" top spacer in the past and really wasn't interested in going that route again. I was looking for a 2" progressive rate replacement spring, but all I could find is 1.5" or 2.5". After sitting on my hands for nearly 3 years, I finally decided that I had to do something so when I was replacing the shocks anyway, I picked up a 2" aluminum bottom spacer for a price I couldn't pass up ($20 delivered including bolts). I installed the 2" spacers with the intention of it being a temporary measure, but I can't actually find any reason right now to spend more money doing something different and I still have yet to see anybody make a 2" spring.
If I wanted the full 2.5", that Carli kit is about the best I have seen. If you want something similar without the adjustable track bar, RCD (Race Car Dynamics) offers a kit with 2.5" front springs, alignment shims and 4 Bilstein shocks for just over $600. As I recall, they offer a taller rear block for the F250 as well.
Honestly if you ever ride in other trucks with there (brand)lifts then its all here say.I wish my truck rode like it did stock.Granted if u make changes be prepared to not or like the results.I hate the one I have now,but tires do some of the damage,so put originals back on to compare.Its sometimes surprising how much a little change makes, then on the other hand make huge changes and not much difference, its a crap shoot.There is a ready lift,or level kits or individual parts in different sorts with track bars,ect.... in diffent levels also for cheaper then most or equal.I right now am planning on lowering mine half as much.Might be going with ready lift 2.5 spacer kit for front,($250-300)just have lots of money in other lift and trying to change ect...I have adjustable trac bar already,so....trial n error.
P.S. I didnt need any adjustment with alignment on most of my lifts,but each on is different.
I never noticed much bouncing on mine when I got it and drove it from texas,but did notice on roads up here.It doesnt do all the time, its the road,but funny thing is that same road you wont feel it with any other vehicle.Now that its lifted ect.... a lot worse but my front is also higher now,hence the change,but not just from this reason.They call it the bounce the super dutys do, not all but a few.I want to take my brothers F350 out and test on same roads some day to verify same results.I dont think there is any fix to it but heard guys that put that expensive carli leaf pack in had good luck,but then need air bags to haul Anything,but I still need those also,doestn take much to squat F250.When I first got my truck It road like a dream,minus the little bounce I noticed up here on certain roads,Interstate mostly, comes and goes as you drive.Ive even noticed looking down the road and seeing the ripples in the road,its new road.lol But dont forget tires make up a lot of the suspension.
That's interesting to hear. I am trying to make my stock truck ride better. My old lifted 2002 rode better than this 2012. This one will actually shake your voice if you are talking while riding down the highway in certain spots. Seems like the rear-end bounces all over the place. I'm hoping tires and shocks will help with some of it. If not, I can't imagine it riding worse.
