1993 lightning motor in 1996 f150 4x4
I bought a 93 low miles rust free lightning for a new body for my slightly rusty 96 f150. Here is my dilemma, I am going to use the low miles lightning motor to replace my high miles Windsor. Since I am using the entire cab from the lightning it should be simple plug and play wiring (both trucks have e4od) but since my truck has MAF should I retain my intake instead of the gt40 one on the lightning?
on
No, the intake has nothing to do with it besides connector types which could be slightly different on the throttlebody, and the GT40 intake is definitely a big step up from the standard truck intake so that's the one you want to use. However your OBD2 EFI system as a few unique parts on it that you will have to transfer to the Lightning motor, those being the DPFE EGR system and the crank misfire sensor. The crank sensor parts will bolt right on but the EGR is gonna be a challenge since the TB is in a different location on the L motor so the DPFE tube won't fit so you may have to fabricate something or disable it with a tuner.
on
In this case I'd have to say using the MAF system you have wouldn't be worth the effort because of the complexity of making it work on the older motor and because you also have a complete EFI system that was built for that L motor. If it was another situation where you only had the L motor without any of the wiring or computer then my answer would be different.
Not trying to sound judgemental, but why would you take the Lightning body off the Lightning frame, along with the Lightning motor, and put it on your 96 frame? Is your frame in better condition than the low mileage 93 frame? Maybe I'm just missing something, but I would rather keep the Lighning intact and cannibalize parts from the 96 to update the Lightning. That's just me though.
