dielectric grease on the contacts INSIDE distributor cap?
I use poor-man's dialectic grease on all electrical connections...petroleum jelly (like in Vaseline). And I do use it on distributor cap contacts, spark plug wire connections, etc. Whether there is any actual value in putting it on dizzy contacts, I don't know. It apparently does no harm.
So you don't think it would cause a stumble or anything? I wouldn't think it would. I've heard of people doing this before but since I've done this full tune up I have a stumble upon acceleration that I spoke of in a separate post that I did not have before tuneup. so I'm trying to eliminate possible problems
before goo : engine ran fine;
after goo : engine not running fine;
remove goo: check results.
Another common use of dielectric grease is on the rubber mating surfaces or gaskets of multi-pin electrical connectors used in automotive and marine engines. The grease again acts as a lubricant and a sealant on the nonconductive mating surfaces of the connector. It is not recommended to be applied to the actual electrical conductive contacts of the connector because it could interfere with the electrical signals passing through the connector in cases where the contact pressure is very low( in this case, no contact pressure at all ... a gap must be jumped ... goo preventing said jump). Products designed as electronic connector lubricants, on the other hand, should be applied to such connector contacts and can dramatically extend their useful life. http://en.wikipedia.org/wiki/Polyphenyl_Ether, rather than silicone grease, is the active ingredient in some such connector lubricants.
Clip cap uses different rotor than screw cap. One uses a round rotor, the other uses an oblong rotor. I think the screw down cap uses oblong one. I'm guessing the grease didn't help it at all either ~Bill
86'F-150
01-22-2013 06:59 PM
LARIAT 85
12-23-2012 10:11 PM
78bigunns
04-19-2008 07:05 PM
