I have a 1995 f250 and rear differential does not lock in when one side spins? Is there something i can do to fix it! Dont know if this helps but it has 3.55s in it!
I'm not real smart about these rear ends. If its a limited slip is there a locker you can install? I'm not sure what the code is I will try to get it tonight!
Axle code 39 would be 3.55 open diff. If the metal tag doesn't have an L between the 3 and the 55, it's open diff. So your choices are a locker as described above, or a limited-slip diff (not as effective) swapped in. Look for a truck with an axle code of C9 (the code for 3.55 LS).
