5w-40 Rotella Synthetic Thought's Suggestion's
Old 11-11-2013, 08:04 AM
tankd72's Avatar
tankd72
tankd72 is offline
I am thinking of switching oil I have been using Rotella 15W40 dino oil since I bought my 2004 6.0. It just turned 101,000miles and I have an oil change coming due soon. I did a search on the 5w-40 Rotella Synthetic and the only in the 7.3 forums was there any discussions. I do have the cold start injector sticking until it gets to operating temp. I am hoping that the lighter oil and being synthetic it may help. The 7.3 guys claim it helps on cold starts and engine diesel clatter is quietier.. Thoughts
Old 11-11-2013, 08:08 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
I run T6 5W-40 all year. I've been happy with it.
Old 11-11-2013, 08:14 AM
69cj's Avatar
69cj
69cj is offline
T-6 is great, my truck loves it. You may also want to check your ficm voltage. That can also cause rough cold starts.
Old 11-11-2013, 08:42 AM
tankd72's Avatar
tankd72
tankd72 is offline
Thanks for the replies I will goe to Wally World and get some. I checked my ficm and had good 56v when it was cold well 50deg I am in Gilbert AZ. I was talking to anoter 6.0 owner while fueling the other day he had the same rough idle when cold. He said that the spool shuttle valve thing on the injectors stick when cold and ford reflashed his truck with a warming option for the valve thing and it works great now. I also saw on You Tube a guy ended up using a whole big jug of diesel kleen silver and a quart of 2stroke oil in his excursion with 6.0, 2 tank fulls later no more sticky injectors, Another You Tube a guy with 6.0 was ready to do oil change tha t afternoon, so He poured a big bottle of marvel mystery oil in it drove around that morning and after his oil change no more sticky injectors. Any thoughts or experiences with either of these?
Old 11-11-2013, 08:44 AM
mohle's Avatar
mohle
mohle is offline
5W40 is good for all year running. Probably the best grade of oil to run. As far as synthetic go, I really don't think there is much of a difference between them all. They are all good. Pretty much personal choice, sort of like what tastes better, Coke or Pepsi.
Old 11-11-2013, 09:17 AM
clevelandtundra's Avatar
clevelandtundra
clevelandtundra is offline
I run T6 5w40 all year round too. Gets up near 90*F in the summer and down to <10*F in the winter. I haven't sent my oil out for any kind of analysis but going off feel I can tell the truck has a much easier time starting in the winter compared to the dino when I drove it off the dealer lot.
Old 11-11-2013, 09:25 AM
tankd72's Avatar
tankd72
tankd72 is offline
Thanks for the input. I think what I may do is switch to 5w-40syn during the cooler months and back to 15w-40 during the hot months because we hover around 110*F-115*F from end of May through September. However I didnt see that Wally World carried Rotella 15w-40 in synthetic only dino.
Old 11-11-2013, 09:37 AM
the_auto_tech's Avatar
the_auto_tech
the_auto_tech is offline
T6 for sure. My truck had 15W40 in it when I bought it and I got to experience a few cold starts with it. The T6 starts MUCH better.
Old 11-11-2013, 10:47 AM
Mich6.0's Avatar
Mich6.0
Mich6.0 is offline
Been running it for years now and no problems
Old 11-11-2013, 11:09 AM
99ExpyProblems's Avatar
99ExpyProblems
99ExpyProblems is offline
I'm switching to T5 10w30. I ran 15w40 and then Delo 5w40. If I like the T5 (won't know for another 1000 miles, I'll be sticking with it for $5 cheaper per gallon.
Old 11-11-2013, 11:18 AM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
Stiction is on the oil side of the injector, not the fuel side.
Josh
Old 11-11-2013, 12:21 PM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
If they don't have that, they should have the Delo 400 5w 40 full syn. It's a touch cheaper and every bit as good as the Rotella. Just another option for you...
Old 11-11-2013, 12:36 PM
dvldog13's Avatar
dvldog13
dvldog13 is offline
I just changed from schaffers syn 5w40 to rotella syn.........was chasing a stiction problem.......talked to Ed from FICMrepair.com. He sells a product called hot shot secret.......It is a oil and a fuel additive to remove the stuff in the injectors...........I wasnt one to believe in a " mechanic in a can" snake oil crap..........but @ 300.00 a pop for an injector.......i tried it...........so far so good......mileage is back up .........running like new.....lots of power...and no i am not an actor or paid professional...........But it has worked so far.....good luck
Mike
Old 11-11-2013, 12:45 PM
jswartz84's Avatar
jswartz84
jswartz84 is offline
I wouldnt think 50* would be cold enough to cause stiction or warrant using anything but a 15W40 oil. Its been in the 30* range where I am and I haven't noticed anything. I'm running Delo 15W40 LE. Of course my oil hardly gets more then 2500 miles on it before I change it due to time. What are your oil change intervals?
Old 11-11-2013, 12:51 PM
Bullitt390's Avatar
Bullitt390
Depending on what PCM/ FICM strategy is loaded can be night and day difference concerning 15/40 and temps under say 40.
Josh
Quick Reply: 5w-40 Rotella Synthetic Thought's Suggestion's
