I hope someone can give me insight on how o replace that pesky bulb in the side mirror marker lamp? I know there are two bulbs in the lamp assembly (one for parking light and the other for turning). I have diagrams, but none discuss how to change the bulb. Ohhh.. 2010 F-250 Powerstroke~
If you turn the mirror all the way out there is a small clip inside that will release the lens from the mirror housing. Pull the clip and then you can remove the marker light and change the bulb.
