351w cranks fit 351c?
If a fella had the mains on a 351w turned down to 351c sizes, would the crank fit? I suppose there are differences in the front 'snout' but that can usually be worked around.
Reason I ask is that stroker 351w cranks are cheap but stroker 351c cranks are not. Seems like an easy way to make a cheaper stroker 351c.
By the time you factor in the machining costs to turn down and repolish/reheat treat the mains, you'll be way over the price of an "as delivered" part from Scat.
Take Care.
Rob!
...anybody know why this forum CHANGES 351-W (without the dash!) to 351w? And...400-M is required so that you don't end up with 400m? If I meant 400m, I would have TYPED it...!
Scat doesn't make any stroker cranks for the 351C but they do make one for a 351W with 351C main journal diameter. This kit uses Chevy rod journals so they can use a cheap 6.00" Chevy size rod and custom pistons. You can get a timing gear spacer from Ford. The snout is also .75" shorter so you may have to add a spacer to the H balancer too.
http://www.strokerkits.com/351c___393_stroker.htm
Kruse
01-21-2017 11:02 AM
doug1222556
35
01-28-2008 11:08 AM
cruz76
03-24-2006 09:14 PM
