Need help - 7.3 PS not running right
#31
UVCH will not cause knocking. Nor will it cause white smoke - no fuel = no smoke. The complete hutch mod will also get rid if the Quick Disconnects, which can introduce air into the fuel when the tank is below 1/2.
Clogged screens, dropped foot, QDs... the possibilities are worth dropping the tank, before you donate your truck to somebody willing to drop it.
#32
OK another update. I put a 2' piece of fuel hose on the inlet of the fuel pump (fuel pump has been replaced earlier this week). Put that hose directly into a 1 gallon container filled with fresh diesel. Truck starts ok, runs ok for about 10 seconds, and starts into the terrible knocking and clouds of white smoke from the exhaust. Let it run for about a minute to see if it would come out of it. Nope. Throttle pedal only makes it knock louder - won't come off idle. Get this - I let run for about a minute and it used the whole gallon of diesel.
Any chance it's the CPS? I replaced it a couple years ago when I was fighting the fuel pump going bad. Replaced with the part from an International dealer. I unfortunately don't have the old CPS to try... Really need this truck to run. Or for sale for $3500.
#33
#34
A lot of the fuel went back in the tank on the return line.
A bad IPR/low ICP can deliver really low fuel pressure to the injectors.
scotttahoe - Upon reading my reply, I came across as a little brusque... and that was not the intent, my friend. It's funny how things sound so much more friendly/helpful in my head, but read somewhat curt.
#36
For the IPR, check to make sure the tin nut is on tight. You can also pull the IPR out and tear it apart to clean the inside of it. Theres a write up on here on how to do it.
For the ICP, unplug the connector and check for oil in the connector, leave it unplugged and start the engine. If it runs better with the ICP connector unplugged then your ICP sensor is bad. The PCM goes into default mode when the ICP is disconnected.
#37
and low blinker fluid will cause your blinkers not to work. I'm not sure if you mean low hpop pressure or what. We don't need to send the op on a wild goose chase.
#38
#39
#40
Ok - well not that either. Fuel pressure with engine off - 55 psi+. Fuel pressure with engine running 55 psi+. So now it started and ran pretty well for about 10 minutes. Throttle now has some effect on engine and not smoking as bad. Then it got worse and worse and now is almost back to where it was running wise. I was able to move it across the yard, but that's about it. Thinking I'm going to drain the tank and start over with fresh diesel. All this started right after putting 1/4 tank of diesel in. Sound like the right next step?
#41
Put a small sample of diesel in a styrafoam cup. If it is pure diesel, nothing will happen however, even a small amount of gasoline present in the diesel will leak from to cup or even melt the bottom out of it.
Right there is your biggest clue.
The station you filled at may have had contaminated fuel.
#43
#44
#45
Well head hanging low and apologies all around. Hooked a hose to the outlet of the pump and filled a couple old fuel cans with gas... Melts a styrofoam cup like gangbusters. Emptied it with the fuel pump until it wouldn't pump anymore. Added 10 gallons of good diesel from town and it runs like a champ. Now gotta go through the fuel receipts and see if it was the gas station or my wife. I would think if it had been the gas station I'd know right away - I'm on the fire department in the small town of 500 people and the guy that runs the gas station also runs a trucking company with like 6 trucks. But whatever - I'm just glad it's fixed. And relatively cheap - I was pricing injectors last night - dang!
So anyway I owe several of ya'll some Starbucks cards. I'll send PMs here later today so I can get an address to send them to you. Thanks everyone for your patience with me. And for future folks reading this - pay attention to the advice of folks on this list! They know what they're talking about!
