EGR delete
If you want to do a true delete there are a couple ways to do.
1 Sinister Style Kit, which takes the EGR Cooler out, and replaces it with a bypass line for the coolant to run through. This is probably the most common system
2. The welded off cooler system. This replaces your cooler with a blocked off cooler which allows no exhaust to flow through, but coolant still can. It eliminates the chance for the cooler leak into the intake.
The Pros.
It gets rid of the chance your EGR valve to plug up due to leaking cooler. Some people see better mileage and some people see other gains. Basically you are deleting the cooler, not the actual EGR valve, since once you tune your truck, the valve is rendered un-used. They do include a block of plate if you want to remove your actual valve, but people have seen issues regarding their fans after unhooking it in certain trucks, best to leave it in there.
The Cons.
Its 50 state Illegal and you will need to run a tuner to tune the EGR out of your truck. Also the EGR Cooler leaking is usually not the cause of your problems, its most likely a symptom of the oil cooler plugging up. You probably wont be able to get into a tuner for under 400 bucks, so you should keep that in mind as well.
What goes into it?
Heres the just of it.
If you are doing the welded shut style, then you have to pull the Turbo, all the turbo piping, the intake piping, the exhaust pipe. Then you can remove the bolts on the passenger side of the intake manifold, loosen the drivers side up, then lift the intake up enough to slip it old one out and the new one in. Hopefully your intake manifold gasket is still good, otherwise you get to do it twice
If you are putting in a sinister style kit, then you need to do everything I just said, and ad the new bypass, but you also need to remove the exhaust UP-pipe and replace it with one that doesn't have the Y piece in it.
Either way, it took me an entire day to do the last one I did, and I hated doing it so much that the kit I bought for my own personal truck is still sitting on my garage shelf. I think that it is better that if your EGR cooler isn't leaking, then leave it in there, and install a coolant filter kit. Its pretty cheap and it will help keep your oil cooler from plugging up.
The Pros.
The Cons.
What goes into it?
The Pros.
The Cons.
What goes into it?
The Pros.
The Cons.
What goes into it?
yeah looks like mine is staying in there. so when shopping around for one am i looking for a coolant filer kit??
I bought mine from XDP, seemed like a good kit, I also bought a sweatshirt from them, didn't like the sweat shirt as much as the Coolant Filter
gpeade
05-18-2019 08:18 AM
