Y block question
Old 12-30-2013, 11:55 PM
BAMA_FAN's Avatar
BAMA_FAN
BAMA_FAN is offline
Y block question
I have a 54f100 with the y block ,and I want to put the igniter point replacement in the distributor, but I can't see the distributor number. All I can see is ford engraved on the side any suggestions on what kit or number to use?
Old 12-31-2013, 10:58 AM
greenmachine55's Avatar
greenmachine55
greenmachine55 is offline
Pertronix 1282 I used on my 1954 Y block engine. I have not had any problems and starts every time!
Old 01-01-2014, 12:26 PM
TxF100's Avatar
TxF100
TxF100 is offline
Be sure that you do not have a replacement distributor. The replacement ones could be the 57 up style which use a different part number.
Old 01-01-2014, 12:35 PM
TxF100's Avatar
TxF100
TxF100 is offline
The 1957 and newer distributor has a vacuum advance as well as a mechanical centrifugal advance located under the breaker plate.* Special weights dampened with small coil springs advance the breaker plate when required by increases in engine r.p.m
Crop Duster
03-07-2017 09:07 AM
51FordTN
01-25-2013 08:12 AM
mario56
08-15-2004 10:24 PM
himmelberg
18
03-05-2004 06:24 PM
Franklin2
02-19-2002 01:13 PM
Quick Reply: Y block question
