New to Powerstroke
#226
#227
#229
No, not really. I may put a little something together once I'm all finished, but I don't have much yet. I've been told they're seats out of a 2003 F-150 and they have the Lariat designation embroidered into them. They were out of a 4 door truck so I have the full rear seats, not like the little narrow "butt shelf" that's in the extended cab trucks.
What I can say is that the fronts are pretty straight forward. I mounted them to the existing front seat pan with a few modifications. I had to drill new holes in the pan for the seats to bolt through, trim one corner off and I went overboard and tunneled the front of the pan so I could retain the use of the front slider handle that was with the seats.
The rears, are not so easy. You either have to drill 14 holes in your floor and bolt them to the seat pan or get creative with your fabrication skills and build a custom rear pan. I'll be sure and post in more detail in the truck's build thread once I get the details sorted out. I was out working on this til about 10:00 last night, but I'm over-comitted on other things so I'm not getting a lot of time to work on this. I'm getting close though.
Where can I get some leather seats?? I would like to put 40/20/40 leather SD seat in the front and Leather in the back of my OBS. Do the F-150s look nice? do they fill it out enough??
#230
Your best bet to get leather seats is to either find some in a junk yard, or find someone on Craigslist that is parting out a truck. I actually like the fit if the F150 seats a little better than the SD seats. The SD seats must be a little bigger and the fit is tighter than I like. It always looks to me like they're kind of cramped in the truck. The F-150 seats seem to fit about the same as the stock seats do. If I ever get the rears seats finished up, I'll take some pictures, lol.
#231
Thanks Nate for the info. cant wait to see the pictures of yours when their done.
#232
#233
Hey Nate, another question for ya.
What year f-150 did you get the seats from??? the 90's to 03 models or 04 and up?? will both work and which one works best?
#234
#235
#237
You have to cut the factory downpipe to get it out of the truck. Use a sawzall and a long blade. Reach up from down below and cut it off as high up as you can then it should come out the top.
#238
#239
