1964 f600
1964 f600
I recently got a 1964 f600 that had sat for 16 year's. Took 2 days but got it running and wow it runs pretty nice for being 50 years old and sitting for the last 16 year's. So i am tring to find out what engine it has the engine code is A and i cant not find anything that says what A is.
Also i was wondering if anyone knows if i can convert it from power brakes it has now to manual brakes? I would think the only difference is the master cylinder but the mount holes are different so i was not sure if it was doable or if anyone else has done it.
Brakes. Do you want to be able to stop the truck? You need to fix the hydrovac system if it is not working.
You will not be able to stop the truck even empty if all you have is a single pot master cylinder without power assist.
Rebuilt hydrovacs are available. Once you determine the model number etc, they are easy to find.
Wheel cylinders & linings are easy to find, drums a bit tougher.
If you post the VIN and the info from the warranty plate on the door, more can be determined via decoding. There might be a couple different sized brakes for example, not sure the decode can tell you that but will help steer you in the right direction.
I recently got a 1964 F600 that had sat for 16 year's. Took 2 days but got it running and wow it runs pretty nice for being 50 years old and sitting for the last 16 year's.
I'm trying to find out what engine it has. The VIN engine code is A and i can't find anything that says what A is.
A VIN engine code (4th digit): 330 2V Medium Duty FT engine / A only used 1964/65.
C VIN engine code (4th digit): 330 2V Medium Duty FT engine / C used 1966/78.
FT: Distributor located in front of carburetor, valve covers have 5 bolt holes per side.
292 Y block distributor located behind the carburetor.
cypslady
13
03-02-2013 09:29 PM
mdkallas
12-24-2007 11:37 PM
psonnier
09-26-2004 09:03 PM
