typical wear or could this indicate more clutch problems!
I pulled a tranny that I thought was bearing issues but actually ended up being rollover. Ate $300 but at least I know that it's rollover since the second tranny did the same thing along with a bad 4th gear syncro so I'm swapping them back since the first tranny didn't grind in any gear.
On both installations I had a squeaky throw out. One in now is even worse.
I thought I would inspect the throw out and shift fork to see if I could see anything that would lead me to believe I have clutch issues as a just in case.
Planning on buying a new shift fork just because this one looks like it was worn out pretty good. Is this normal wear out of the shift fork or is this something more. I just wonder if the clutch is actually pushing against the fork too much and causing this wear? I suspect this wear was not allowing enough pressure against throwout when clutch was engaged resulting in the squeak. Any thoughts? Would anyone agree? disagree?
I was thinking about it. I figured that aint gonna be a really expensive part so I might as well! The divot def had some wear but ball pivot in trans looked pretty good but I'm gonna swap anyway since its out. Dropped my fluid out of tcase so the ball is rolling! Just call me Doc Patrick. Bill, i could wheel u in the garage and do some operating on u too while I'm at it. Haha. I'll ask these guys on here for advice on your procedure!
on
1 Post
These guys!?!?!?!.........trucks yeah........me, uhhhh NO! LOL!!! They would have me looking like Frankinstien or a robot or something! I'd have lights on top my head, gauges stuck to my forehead, a 5" stack sticking out my butt! I think I'll let the doctors handle this one! LOL!!
one step closer to pulling trans
I got the shift fork out the trans I'm swapping out tonight. It was really worn out at the pivot ball. Looked just like yours Bill. Got the tcase removed.
The Tcase looked like this:
I can't tell if the leakage is coming from the shift lever hole or blowing out the vent tube. Regardless, I want to break this the clamshell and reseal since I recently sealed the tail housing b/c the gasket material was gone and leaking! I expect the clamshell to have very little sealing power left too.
Anybody have any tips on breaking it? I've heard you have to open it a certain direction or it gets messy. Any advice on where that leak might be coming from?
I'm ready to pull trans but I want to get the Tcase cleaned up and resealed before reassemble. Making progress. Farther along than I thought I'd be this weekend!
Jespo80f150
07-11-2012 04:04 PM
CowboyBilly9Mile
1983 - 2012 Ranger & B-Series
03-27-2004 12:01 PM
