93 bronco e4od mass air conversion
I have posted a couple of times about this project and appreciate the response I have gotten.
As I have said in previous posts, ford motorsports does not offer a kit for trucks/ broncos with e4od because mustang processor will not work. I am trying to get the parts together out of a junk yard to do conversion. My question today is can I use the proccesor out of a 2wd truck or a van? My bronco has push button or electronic 4wd.
Thank-you for your help
Dave
Dave
>Dave
I have the following info.
to convert sd trucks with E4OD to MAF use the CA 5.8l MAF/E4OD (F5TF-12A650-BYA). Mike wesly uses F5TF-12A650-HB (95 CA 5.0 MAF/E4OD). you can also use F5TF-12A650GB.
THE BYA and HB versions are set-up for 4:10 gears and the GB version is for a 3:55 ratio.
hope that helps.
most trucks were speed density up till 95/96 i believe.
>Dave
hope that helps.
