I just replaced the right rear caliper due to the caliper sticking and getting the rotor hot. after replacing the caliper the brake pedal is mushy. I do not recall it being that way before replacing the caliper. I have bleed that brake line but still have a mushy pedal. It does stop the truck but I feel slightly uncomfortable with a mushy pedal. am I missing something? thanks
Then that is your problem. You were sold a drivers side caliper for your pssenger side. The bleed screw has to be on top to work properly. You'll never get all of the air out of that caliper.
