4.9L E350 clubwagon will not downshift
My wife has a 1996 4.9L E-350 Econoline Club Wagon van. The problem we are having is that the vehicle will not downshift. When you first start it it begins in low and up shifts just fine. When you slow down and then begin to go again the transmission will not downshift to a lower gear. You can manually shift it down by the shifter. The speedometer is working just fine and not bouncing. Curious as to what sensor it would be. The Variable speed sensor on the rear differential or the speed sensor on the transmission. Just not really wanting to replace every sensor if I do not need to. Please help.
Redneck1465
11-04-2009 10:00 AM
