Powertrain replacement advice needed
Old 10-14-2013, 02:01 PM
dcagnolatti's Avatar
dcagnolatti
dcagnolatti is offline
I've decided to replace the motor and tranny on my '59. Engine troubles have been frequent and the tranny needs a rebuild, so I decided to punt.
Anyone have suggestions about new power trains? I'm not looking for hot rod power. I'm only interested in having a dependable driver fir frequent use.
Old 10-14-2013, 02:35 PM
oldebrush's Avatar
oldebrush
oldebrush is offline
I probably won't be much help here, but I installed a good running 69 302 cu.in engine, stock with a 2 bbl. carb, and its factory C-4 trans. I am retaining the stock 9" rear, but may change gears for a higher ratio. It is not running now, but it did run well in all aspects.
I was looking for reliability, and simplicity. I don't care much for the newer injected, computerized engines and trannys that many are installing these days. I have grown too old to adapt to the modern day technologies.
Best of luck on your choices for replacement driveline.
Aloha, Tony
Old 10-15-2013, 05:35 PM
Damifiknow's Avatar
Damifiknow
Damifiknow is offline
I'm gonna do a 302 as soon as I gots some money. It will mate to my T5 nicely and parts are all over the place.
Old 10-15-2013, 07:24 PM
spurredon's Avatar
spurredon
spurredon is offline
Nothing wrong with a '302!
Old 10-18-2013, 08:06 PM
Maltman's Avatar
Maltman
Maltman is offline
M9Hellman
04-18-2017 09:11 AM
olblue77
03-05-2014 06:37 PM
ddiaz12
46
01-27-2014 10:07 AM
Michael McDonald
06-08-2004 04:10 PM
Jake
08-17-1999 07:32 AM
Quick Reply: Powertrain replacement advice needed
