Cutting the "door open" wires
Awhile back while adding replacement power door lock actuators, I unintentionally cut the wires that tells the truck when the door is open.
And I kinda like it!
After turning off the truck, the power windows stay active even after opening a door. (They timeout after about 5 mins).
The overhead light does not come on when I open the door. (If I want the light on I just press unlock on the remote FOB and they turn on, or I manually turn on the map lights.
I think you just half-answered a question I have on an electrical issue I have on the 2002 I recently got. After I remove the key, both the radio and power windows remain active for a few minutes too. Could this just be that a wire was cut at some stage? I was thinking the radio wasn't wired on the proper AUX key position but it definitely goes off after a while.
Also, is there a seatbelt dinger fuse you can remove, or do you have to cut a wire for that? I guess I could say I drive a lot on private property with no belt, but that would just be a lie.
I'd really like to disarm that fricken' dinger though.
So you don't have to cut anything "in you'r truck," you can go down to the local junkyard and cut out the old seatbelt clicker and click it into your truck. It's kinda like tricking your truck into thinking that the seat belt is on.
Received 3,108 Likes
on
as for the seat belt chime, i just unplugged the seat belt sensor wires under the seat.
on
yes you can, but you have to do it every time you start the truck. unplug the weight sensor and you never have to mess with it again.
To turn it for just one cycle just press the belt release button.
on
Thanks for the responses guys, and sorry for the delay in replying. So, I have electrically operated seats with seat warmers. I really don't EVER want the seat warmers or seat belt chime, but want the electric adjust to work, so is there one plug for each, or will I need to unplug specific wires? Anyone know, or have a wiring diagram handy?
Thanks again,
Thanks again,
I did that on the wifes Windstar when I drive it! On BigRed I just hit the belt unlock button and it shuts off!!
Smokie
I'm telling you man, the easiest thing to do is go down to the local junkyard cut the strap pull the seat belt clicker off the junkyard truck and plug it into your seat. That way you are not cutting any wires and can easily go back to factory if you decide to sale it. What you are doing is tricking the truck into thinking the seat belt is on without disturbing any wires. You can easily un-click it and put on your factory seat belt with the strap when you want to. Does this make sense?
