Question on Tires
Question on Tires
Need your understanding on type of tires for heavy duty truck. I know that we need to have E rate tires for our truck, but is it necessary the tires need to be 10 plys combine with the E rated? There are E rated tires that only have 4 plys, is this acceptable to use?
Thanks,
Thanks,
Today's load range/ply ratings do not count the actual number of body ply layers used to make up the tire's internal structure, but indicate an equivalent strength compared to early bias ply tires. Most radial passenger tires have one or two body plies, and light truck tires, even those with heavy-duty ratings (10-, 12- or 14-ply rated), actually have only two or three fabric plies, or one steel body ply.
http://www.tirerack.com/tires/tirete....jsp?techid=55
Thanks,
I think so. Of course it depends on how your truck/trailer is set up, but an E rated tire should be more than adequate. For example I'm currently running the Goodyear Wrangler AT/S tires (LT275/65 R 20), Load range E, rated at 3750lbs at 80psi. So, 7,500lbs max on the rear tires (single rear wheel truck), and my rear axle is rated at 6,100lbs. I'll overload the truck before I overload the tires.
spikedog
01-30-2004 08:13 AM
92Custom
06-27-2002 03:40 PM
