Ramblings of an F100 Noephite
I have a '72 F100 and it is my first. Like many, I'm doing the work by myself. I have removed the engine and transmission, as well as, the interior. During this exercise I have learned a few things: 1. You need the people in FTE; 2. Don't expect the national part stores to be much help; 3. the rear engine support is actually on the tranny; 4. the engine will not balance on its mounts; 5. it's best to drain the tranny's oil before removing it; 6 if you are going to clean the engine compartment get a first aid kit; some people will drill a hole even if they don't need it and lastly do it because you like it.
BTW where do I get the bushings for the shifter rods?
Located at the bottom of the steering column under the hood are the two manual control selector levers that the shift rods attach to.
Shift rods attach to two selector arms on side of trans.
Thanks numberdummy. I need the ones on the 7302 assembly, I think There is nothing there to compare. In technical terms: There is an ear on the steering column (inside of the engine compartment) that connects to a rod that goes to the side tranny to change gears. The rod is adjustable the tranny end.
scuttlebutt
07-30-2021 09:36 AM
‘66 F100 Pearl
11-04-2018 01:28 PM
stp1971
13
04-02-2013 05:25 AM
59'er F100
04-10-2007 03:23 AM
jasonh300
06-27-2003 07:36 AM
