Nitto Mileage
Old 10-08-2013, 02:24 PM
AMEC Electric LLC's Avatar
AMEC Electric LLC
AMEC Electric LLC is offline
Nitto Mileage
47k on my 37" Nittos! I think its time to replace them. Has anyone seen better mileage on 37s? If so, which brand? Mud or All-Terrain?
Old 10-08-2013, 05:00 PM
acf6's Avatar
acf6
acf6 is offline
Damn. Never seen anyone get more than 35k miles out of those
Old 10-08-2013, 07:24 PM
kper05's Avatar
kper05
kper05 is offline
Wow, that's about perfect. I'll already be well into my second set at that mileage.
I'm going to try to make it to March 2014 which will be two years but mine have
been wearing quickly.
I only have 20,000 on them and I doubt I'll make it to 30k.
I know of one set of Nitto Terra's (on a Dodge 2500) that made it to 60,000.
In fairness, those should have been replaced at 50,000 but even then that's still very good.
I realize that's one of those stories along the lines of "I tuned my truck and gained 20 MPG" but it's factual.
I'm sure a reg cab Dodge is lighter anyways.
Old 10-08-2013, 08:45 PM
Andrew010's Avatar
Andrew010
Andrew010 is offline
15k and my rears are 3/4 gone. Fronts are about half.
I won't get 20k out of a set.
Old 10-08-2013, 09:08 PM
SavageNFS's Avatar
SavageNFS
SavageNFS is offline
Received 7,068 Likes on 2,217 Posts
I run Toyo MT's and I'll be lucky if I get 30k
Old 10-08-2013, 09:30 PM
Chad149's Avatar
Chad149
Chad149 is offline
I've always had good luck with BFGs. My last Super Duty got 60k out of the mud terrains, replaced with some all terrains, those had 50k on them when I sold the truck with lots of tread left. Problem I see here is the lack of choices for our plus size wheels. And yes, I drive like an old man.....
Old 10-09-2013, 04:07 PM
EpicCowlick's Avatar
EpicCowlick
EpicCowlick is offline
Toyo MT's are done. I got over 42,000 miles out of them and will get a new set shortly. They never needed a re-balance and only once did I put a plug into one of them. You can still see the siping marks from two years ago. Funny thing, the passenger side tires wear faster than the driver's side. Anyone else notice that?
Old 10-09-2013, 04:29 PM
Shepardsonp's Avatar
Shepardsonp
Shepardsonp is offline
i wouldn't let your wife know that the passenger tires are wearing faster than your side
Old 10-09-2013, 04:36 PM
EpicCowlick
Good one Paul.
Old 10-09-2013, 05:02 PM
acf6's Avatar
acf6
acf6 is offline
Love my toyo mts as well
Old 10-09-2013, 05:19 PM
BigF350's Avatar
BigF350
BigF350 is offline
http://s160.photobucket.com/user/tj5...211be.jpg.html
42k miles is good too.
When you get new tires fitted, with the wheel alignment get them to check that toe isn't too high on the passenger side. Even the slightest increase in toe can really exacerbate wear.
Old 10-09-2013, 05:38 PM
AMEC Electric LLC
Mine wore more on the drivers side. At the cost of these things, I will get the alignment checked now that you've mentioned it.
Old 10-09-2013, 06:19 PM
FishOnOne's Avatar
FishOnOne
FishOnOne is offline
Received 1,447 Likes on 893 Posts
I've noticed the same thing. I contribute that to left turns are typically wider turns at a higher speed vs. right turns that are typically tighter turns at lower speeds.
Old 10-09-2013, 06:51 PM
Tomahawk's Avatar
Tomahawk
Tomahawk is offline
I thought it's drive shaft torque, pushing down on the drivers side for better traction and lifting the passenger side causing it to slip and wear faster.
It's not the wife, but it could be the MIL.
Old 10-09-2013, 09:14 PM
SavageNFS's Avatar
SavageNFS
For whatever reason the rear tires are wearing faster than the fronts and there is black bits all over the rear quarter panels. I just don't understand...
Quick Reply: Nitto Mileage
