Yet another thread about fuel gauges
I have an 89 F250 w/351 and dual tanks. The tanks draw gas fine, but if the switch is set for the front tank, the lowest it shows is half a tank. Even if the tank is empty and you add a couple of gallons of gas, the fuel level gauge will rise. The rear fuel gauge works fine. I've read conflicting information about how the gas gauges work on these trucks, so any information would be helpful. The strangest thing to me is that my initial reaction was a stuck sender in the tank, but if the tank is empty and you add 2 gallons, the fuel level shouldn't raise high enough to affect the sending unit.
Thoughts?
Thoughts?
The fuel gage works off of resistance like a multimeter. I do not know the scale for the fords, but for instance on most GM cars 0 ohms is full and 90 ohms is empty. So probably have a loose or corroded connection some where in the sending unit that is not reading correctly. You can eliminate the gage and front connections as being bad because the rer tank reads good you said. Unfortunately you may need to pull the sending unit to check the connections
Matt
Matt
Old Brown Truck
10-07-2014 08:17 PM
Wayne Waldrep
29
06-07-2014 08:56 PM
straightedge
06-01-2004 12:51 AM
bearclaw
07-08-2000 02:47 PM
