New Garage/Shop
#587
Wife's cousin called around 12:45 and wanted to know what I was doing. He was supposed to be doing a concrete pour in Cape Charles today, everything was supposed to be ready for the inspection and pour. It is a big slab floor with buried plumbing. Friday and Saturday the system held water perfectly, when they arrived today, it was empty so the plumber has to dig everything up and find the leak(s). Whoever the job is for is having a fit about it has to be done by Friday. He is about fed with it. He came with his crew and started closing part of the inside walls as far as he can till I get the next electrical part inspected.
#589
#590
#591
#592
#594
Just this morning I was called to my friends garage because he said there was no power, but the lights were on
When I checked the garage subpanel the neutral was bad.... but those LED shop lights were still shining bright because they draw so little current and the drivers adapt to
lower voltage.
The LED's themselves only require something like 3V to operate.
lower voltage.
#595
I bypassed the ballasts in the fixtures, and swapped out the bulbs.
They come in 4k and 5K for $8-9 a piece. (Dozen per package)
2000 lumens but no mention of CRI.
Mostly did it because they draw half the wattage of fluorescent and come on instantly in the cold
#596
#598
#599
#600
Looks like drilled angle iron, I think you can get that at lowes.
As for shelving, I'd use Advantec sub flooring, It's got a 50 year warrantee, so it'll hold up to being used as shelving and it won't bow, cup or twist like regular linear boards and even plywood.
As a side note i used to have one of the post jacks like that orange one in your picture. I had to leave it behind when I lost my house.
I got it from a high school when I was in high school, and rebuilt it and brought it all the way from California to Missouri.
