Truck ran with old tanks and pumps. Won't start with new ones
Hello all (and most hopefully Subford),
95 F-150, 4.9L, 5speed manual
I was having poor fuel pressure issues with my two old tanks and pumps. Once I got the bed off and looked inside, they were filled with sludge and darn near black gas.
Rather than spend the time and money to clean the tanks and put in new FDMs, I found a Spectra Premium bundle online that included new tanks, new hangers, new FDM, etc. I bought both a front and rear setup.
I've got them both on and wired in. I had to cut off the Ford connector and splice on a new one. I'm almost positive the wiring is done correctly. I've checked it against the both the original tank wiring and the original wiring connector.
However, I have a no-start situation. Both pumps prime when the key is on. Both put out 55psi when cranking. But the damn thing won't start.
Inertial switch is in the normal, non-tripped position. I appear to be getting spark. At random, it will act as if trying to start, but never runs.
I'm going to swap some wiring again to see if that helps. Any insight you can provide will be greatly appreciated. I only hope it arrives before I bald myself pulling my hair out.
Thanks!
EDIT: She's throwing a 542 code, KOEO. And I tried switching the wires: no dice
Thanks!
Ok, I've checked and I do have power to my injectors. The noid light flashes when cranking. I've pulled a plug and confirmed I do have spark.
The pumps still prime when I turn the key, but I've made no progress. Every fuse in the truck is good. I've tried swapping relays, but to no effect.
How can I ensure I'm getting air, or my sensors are registering properly? I'm at a complete loss.
Throw out any and all suggestions and I'll check em. This is nuts.
Thanks
EDIT: I'm thinking it's a timing issue. I tried running it with starter fluid: no dice. She won't start. If I put the pedal to the floor, and try without starting fluid, she will backfire. If I try with starting fluid, I have fire shoot out of my intake. So, how do I go about checking timing, ie, which notches on the flywheel?
Thanks
All,
Ok, so I've got it running and took her for a spin. She generated a 998 and a 122 code. I find that odd because I just replaced the TPS. Did I forget to do something I should have? I bolted it back up and plugged in the harness. Did I miss something.
She stalls out at idle, but is driveable if I keep the RPM up. She does tend to surge a bit, though
Ok. I read on one forum where the MAP sensor can give problems, so I disconnected both the vacuum line and electrical harness. The truck immediately began to idle better, so I bought a new MAP sensor, hooked it up. Bam, the truck won't idle now.
I've made progress, as it will now run when full warmed up. I appreciate the help, guys. Now if I can just get her to purr while idling.
homer14
2009 - 2014 F150
05-04-2018 08:25 PM
1993ford
17
04-19-2015 09:57 AM
JOHNTC
09-03-2007 08:20 PM
mrblorry
26
11-26-2005 11:22 PM
