Tranny reflash lost MPG, why??
I had an erratic shift in my 2012 F350 4x4. It was between 1st to 2nd gear and 2nd to 3rd.
I called the dealer ship and they drove it and couldn't duplicate the same thing but they said the modulator needed to be reflashed with an upgrade. Well it seems to helped the erratic shifting but I have lost MPG.
I was able to obtain 22 mpg and now after 1500 miles I have to feather it just to get it to 20 MPG.
Why the drop? Has anyone else had this happen? Can they take the reflash out of it to get my MPG back?
2012 F350 4x4 Crew Cab with 3:31 gears. 14,000 miles on the truck
Tore
Tore
Tore
Tore
I had the solenoid TSB performed at 25,000 miles and it seemed a little better for a while. Now at 40,000, it's just like when I bought it three years ago. The more throttle input I give it, or when it's loaded down, the smoother it shifts.
Good luck!
Imight take it back and see about having it removed.
Never tried the manual shifting.
Tore
Tore
Good luck with trying to go back! Once they flash you to the latest version, they cannot go backwards. IDS will only allow the latest version installed on that computer to be installed. In other words, unless you found somebody that had an old version of IDS, there is very little hope of going back to the version you had.
My truck does this every morning. It will jerk back and forth between 1-2, 2-3 sometimes. My truck is a 2011. A few months after having it I had the dealer reflash a few things (NOX sensor, transmission). The transmission really improved the performance overall. I just consider the jerky operation when cold a characteristic of the truck. Once I'm a few miles out it stops. The colder it is the rougher it is.
As to the mileage, I didn't pay any attention to it before/after reflashes. I am averaging 17 these days. Sometimes I hit over 20 when I am on a long trek, sometimes 14. It all depends on the conditions. Still, 17 for a 1 ton is decent. My 1/2 ton was 14 and my 6.4 maybe around 15-16.
What happens if I use manual mode is I forget to shift the dang thing! LOL!
I haven't used it enough to get a feel for how well it does or doesn't help.
I had the solenoids changed 15,000 miles ago hoping that would fix it. It helped for maybe 1000 miles. It's back to the same old crap. I have come to the conclusion that it is what it is. While I don't have the flares that John used to have that eventually led to him trading off the truck, I am curious if the later models are experiencing the problem. That is my main reason for wanting a new truck. I would still get another Ford, just hopefully one that shifts better.
It's been so long I can't remember when my truck began the shifting issues; maybe 3000 miles.
The solenoid change did fix the main issue where my engine would high rev between 2nd to 3rd gear.
Now, it just stalls for a second but that's better than 2-N-3 with 3500 RPM 2 minutes after a cold start.
Some days when it stalls, I have had enough and punch it.
Hi gang,
Any physical concern with your truck should be brought to the attention of your dealership so they can inspect. Additionally, I'm always happy to research ways to help, too; to get started, send me a PM with your name, phone number, VIN, mileage, daytime phone number, and full name.
Crystal
Crystal
The dealerships do what they can but it's difficult to reproduce and there is never a CEL.
I never even got a CEL when my turbo stopped working so there is no way a bad shift is going to throw one.
I have a good customer based relationship with my dealer so there isn't an issue there.
Without a CEL, Ford corp. says there is no concern.
It took 36,000 miles before I even got new solenoids.
I'm tired of giving my truck up for these silly issues but when I'm ready to dive into this again I know you are here to help us!
My shifting issues started pretty early on. In fact, my first post in Nov 2010 was about tranny shifting issues. I bought the truck in Aug 2010.
I have used the M-mode only once so this has all been in drive mode.
I have no complaints thus far.
Hi gang,
Crystal
Crystal
Each trip to the dealer had me have the writer hand write on the ticket - "no flash".
The one time I forget to tell the writer ..............
Yep, trans flashed for a problem I did not have and my mileage out right stinks now.
Towing, I went from an average of 11-12.5, depending on my speed to 9 - 9.5 regardless of speed (within reason of course).
At my level that is a 20% drop.
My comparison is almost identical 5th wheel trips between years. One year ago, 2 trips, 1800 miles and 1400 miles.
This almost identical routes and miles. A $200 plus cost in diesel for a service I neither wanted or needed.
Hi gang,
Crystal
Crystal
Tore
