1950 Ford F1
1950 Ford F1
Hey guys new f1 owner here. After inspecting it I discovered the front crossmember has been cut off flush with the frame to accommodate a 302. I have a flathead 8 I'd like to put back on the truck. I'm looking for some advice on what route to take to place the flatty "back in the truck" thanks Quenten
Yes pictures would help, but I can't help but wonder if maybe just the curved portion of front crossmember (part that the front engine mounts too) is what's missing?
My F1 had those taken out by the po as well. It had a 283 ? in it I think. The 302 should fit fine without messing with the front cross member, at least I would think it should?
The fact that he's telling us that it has a 302 tells me that there's probably a 99% chance that the original tranny crossmount is missing, and he might actually be talking about that. Then I would also assume that he could be talking about the flathead motor mounts up front. But, like said earlier, there's no way both the front and tranny crossmounts could be missing. That would be like trying to drive two big 2x8 boards down the road with nothing in between them.
Re
Thanks for all the responses I didn't expect all the responses so thank you.the tranny mount is there it's butchered but holding a c4. Also the crossmember I'm referring to is the one with motor mounts. My location is southport nc. I'm on duty until tomorrow I will take pictures first thing. Thanks again.
Hey Quenten,
Welcome Aboard! It's great to have another 1950 F1 owner joining up.
You'll have a great time. Good luck - Post some pics when you get a chance.
(The easiest way is to join the site for $20 then you get a little paperclip icon & post pics directly from your harddrive).
I was just out changing the oil in our '50 this morning - well let me correct that - I was watching my 21 year old son change the oil. I was coaching.
Good luck over there in beautiful North Carolina. (You could get stationed in much worse places).
Ben in Austin
1950 F1 (351W/AOD)
Ben in Austin
1950 F1 (351W/AOD)
on
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html
1. Login to FTE.
5. Click Upload.
Welcome to FTE!
Hope that helps.
