77 300 6cyl fan removal
Old 10-31-2013, 12:39 PM
ihornsby's Avatar
ihornsby
ihornsby is offline
I have a 77 f100 Custom with a 300 inline 6cyl. My question is on the fan removal. It doesn't have a fan clutch. There are a total of 5 bolts holding the fan blade on. The center bolt, is it left handed threads? I was able to to remove the 4 surrounding bolts but the center bolt didn't seem to want to budge. I'm thinking it is reversed threaded.
Thx for the help.
Old 10-31-2013, 01:01 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
I don't think that center "bolt" is actually a bolt. Rather, it is the alignment boss on the fan spacer.
Old 10-31-2013, 01:06 PM
ihornsby's Avatar
ihornsby
ihornsby is offline
Humm, I'll look again, but i swear i thought it had a "Bolt" machined head on it.
Old 10-31-2013, 01:08 PM
Rory428's Avatar
Rory428
Rory428 is offline
Agreed, the center is simply an alignment pilot for the fan. Once you removed the 4 actual fan bolts, the fan and spacer SHOULD come right off, however, it is not uncommon for corrosion to cause the fan to stick to the pilot, and /or the spacer to stick to the water pumps pilot. usually a couple of taps with a hammer will pop it off.
Old 10-31-2013, 01:09 PM
ihornsby's Avatar
ihornsby
ihornsby is offline
Originally Posted by Rory428
Agreed, the center is simply an alignment pilot for the fan. Once you removed the 4 actual fan bolts, the fan and spacer SHOULD come right off, however, it is not uncommon for corrosion to cause the fan to stick to the pilot, and /or the dacer to stick to the water pumps pilot. usually a couple of taps with a hammer will pop it off.
Ok, Cool... Thx for the info. I'll try that.
Old 10-31-2013, 05:43 PM
ihornsby's Avatar
ihornsby
ihornsby is offline
Came right off with a bump of a hammer. thx guys
ahub421
WTB - Parts & other
05-21-2016 12:19 PM
Sheryle
11-23-2010 06:24 PM
khadma
07-14-2008 05:03 AM
Bill Lamb
27
09-10-2007 08:14 PM
turborich
33
10-11-2005 08:51 AM
Quick Reply: 77 300 6cyl fan removal
