Left for work last nite, home on a tow truck 5 1/2 hrs later
So much Time, energy,and money, put into this truck. It all seems wasted and futile again. I really like (used to be love) my truck, spent many many hrs, days updatein, fixin, polishin, rebuilding, + countless hrs here studyin, learning, gettin advice (which is priceless, and I seriously thank you all for that, makes me all warm & fuzzy thinkin 'bout the money I've saved and the knowlage I've gained from this Forum, thanks again for that, givin freely, to the masses) tinkerin, and maintaining this truck, doing every thing I possibley could to keep her happy. I would have kicked a woman to the curb long ago if she was this tempermental and high maintainence....So if your still with me I headed out to work early last nite to compensate for the time it takes me to go around all the washed out bridges here in colorado (just about all of them) truck was runnin good, I was happy thinking about all the repairs I'd done 2 months ago including a new oil cooler,welded shut the EGR, HPOP rebuild, Turbo rebuild, blue spring upgrade, new degass bottle, new raidiator hoses, and wireing clean up. not to mention all previous repairs, too many to list. Then after comming off the interstate and leaveing a stoplite started loseing power and died almost before I could get thru traffic to the side of hwy 34. smelt and could see raw vaporized fuel comming from under hood. Truck would start and run very rough for a minute and die with vaporized fuel everywhere but lookin over the top and crawling under I couldn't find the source. sorry bout the long post I'm procrastinating getting out side and tearin it apart enough to get a better look in there. The truck will still start, all hoses, intake and exhaust pipes seem to be intack so I'm going to go inspect a little more throughly. Any takers????
Okay, so what exactly are we leaking? Exhaust fumes or fuel? If it is fuel, I will agree with the post above. There really isn't too many places where fuel can possibly leak out under the hood, given that the fuel passages are internal to the cylinder heads, save for the secondary fuel filter housing along with the supply/return lines to it and the supply lines to each cylinder head. All of this is pretty much located to the area around the driver side front of the engine compartment (with the exception of the supply line to the right head). So pinpointing the source shouldn't really be too difficult.
ok after further inspection I've got exhaust and what seems to me to be unburnt fuel comming out of that crack in the bellows on the egr side. almost seemed like it was hydrolocked when I started it up and it idled fairly good. I cleaned it all up and am waitin for it to dry before I attack it again.
If it is indeed fuel coming out of the exhaust, then you may have a stuck open injector. I am in the process of replacing a piston and head on a 03 that the owner drove a couple hundred miles with the #7 injector dumping fuel in the cylinder. It looks like someone took a torch to the top of the piston and valves.
I could see a weld breaking. Never trusted welded egr coolers. Deleted is always fail safe
Pull all glow plugs off the passenger side cylinder head. Disconnect all four injectors on that bank. Crank the engine over to pinpoint the offending cylinder(s). Identify the fluid. If it's fuel. Pull all four injectors to pinpoint the offending injector(s). If it's coolant, the EGR cooler is your culprit.
Ok after a good power washing and a quick startup to move back into the driveway I'm thinkin stuck injector because of all the raw fuel comming out of the crack and stacks.I did the welding on the EGR, two plugs on each end so I don't think its coolant. I wanted to delete it but also want to pass the sight inspection for emissions.
[quote=m-chan68;13551968]"Pull all glow plugs off the passenger side cylinder head. Disconnect all four injectors on that bank. Crank the engine over to pinpoint the offending cylinder(s). Identify the fluid. If it's fuel. Pull all four injectors to pinpoint the offending injector". (Not sure I'm getting this right. I'm pulling the glow plugs to see what comes out of the hole while cranking over motor. correct? If I disconect the injectors how will I know which ones bad?
