All of a sudden my 300 six with the YFA one barrel is running very poorly when I drive. Oddly it idles perfectly at 700 rpm. There is some unburned gas smoke from the poor combustion. Looking for some initial fix reactions. I've never opened up a carb, always feared having leftover parts. Thx. Steve
You can feel it misfiring badly, but not ignition cause it purrs at idle. To me it says the idle circuit is set right but when the throttle opens the mix is off somehow.
Or, ignition components [i.e. plugs, wires, etc.] are needing attention. When a load is placed on the engine, ignition weakness will show up, but at low or no loads, everything will seem okay.
If it is in the carb, then it would be the main jet is clogged or partially clogged. You can test this carb theory;
Rev it up till it starts acting up. Then blip the throttle, but keep it revved like you had it before you blipped the throttle. In other words keep it above idle. If the engine suddenly clears up and then reverts back to missing, then you do have a clog somewhere in the main fuel delivery inside the carb. By blipping the throttle you are adding fuel by the accel pump, and if the engine is running lean because of a carb problem, this added fuel will "fix" it for a short time till it burns that up.
That "blip" test didnt reveal anything...it acted normal.
I found a cracked rubber cap on the vacuum tree under the carb, but no real change there either.
I remember a rich/lean test from many years ago I will try.....gradually cover the top of the carb to see how it affects its running.
Check the EGR and make sure it's not leaking or burnt out. You can make a block-off gasket out of a piece of thin metal to see if that helps it. I usually use the thin stuff you use for flashing. It will won't last too long but it's good for a experiment.
