Plow with lift?
Plow with lift?
Howdy everyone.. I was wondering how a plow would work on a 02 powerstroke with a 8 inch lift and 38s... A chain plow that being. I'm not sure if you could just lengthen the chain and have the plow pull up less than with the original chain? Or its not possible? or whats the deal, could really appreciate the help as winters right around the corner here in the Northeast.
Unless you plan on getting rid of your truck in the next couple years don't put a plow on it. Plowing is quite hard on a truck and with has modified as yours is you would only be making it worse. The plow frame would still need to be in the correct position relative to the ground so you would pretty much have about 18" of frame hanging under the front bumper at all times.
If you want a truck to use for plowing your own small area get an older used truck where parts are cheap and abundant. You can buy an older truck with the plow already installed for less than the price of a new plow for your current truck. Then you just have to replace what you break with parts from the junkyard.
If you are thinking of doing this commercially you need a different truck with near stock suspension. Also, for a commercial plowing gig you need to have some kind of backup if your primary plowing vehicle breaks down. A customer isn't going to care that you don't have a truck if there's a foot of snow in their driveway. They will drop you fast and find somebody else.
Okay thanks everyone, so which one? extra frame or separate truck? I would probably start doing or wanting to do commercial work as I already mow lawns semi-commercially/landscaping... I think it wouldn't be a bad idea to just get an older truck but wouldn't it be tough to balance the extra older truck in the winter? I live northwest of Boston and typically average between 80-100" of white stuff every year.
If you are doing this commercially you need a separate truck. You will be putting way too much stress on your truck. By the time you got done fabbing up an 8" drop for the plow that can take the load it's going to weigh over 500lbs on it's own and will probably still break.
Also, plowing is a whole new thing. People will call you at unbelievable hours to come plow their driveway. If you get a bad storm you will be running on very little sleep and a whole lot of coffee.
If your truck breaks you need to have a backup. Your customers won't care why you don't show up, they will just know you didn't. The backup could be a second truck or be prepared to pay another company to fulfill your obligations until you are able to again.
The best option if you want to get into plowing is to start out with somebody who is already established. Whether you are running their truck or running your truck as a subcontractor, you need somebody who can back you up until you get to know the business.
Just remember that no matter what truck/plow you run, it will break in the middle of a blizzard.
Plowing can be a very good way to make a few bucks during the winter or lose your shirt trying.
Along with all the equipment problems you will also have to deal with people. There will be guys who buy a 30yr old truck that's made of more rust than steel and they will offer to plow for less than your fuel cost and still be convincing themselves that they are making money while putting you out of business.
Received 3,108 Likes
on
Yeah looks like I'm in luck, theres a actually pretty nice 94 f350 turbo 7.3 for sale around 1900.. I could take a thousand off it possibly or offer em like 600 and the best thing is it's a flatbed, so a sander is already ready! Thanks again everyone
limptera13
12-28-2010 10:24 AM
1977f150xlt
16
10-09-2009 01:18 AM
1970f2504x4
09-04-2003 02:58 PM
rebelbob
05-30-2003 10:42 PM
