fuel pressure gauge
09-11-2013, 08:46 AM
on
fuel pressure gauge
where can I get the fitting for testing fuel pressure
09-11-2013, 08:47 AM
A hydraulic shop. The fitting is 1/8 NPT x M12 x 1.5
09-11-2013, 01:17 PM
I got mine from Diesel Manor, along with the fuel pressure gauge.
By the Way........ what's the correct fuel pressure I should be seeing with the blue spring upgrade ?
My gauge sits very steady on 65psi............. is this correct ?
TIA.............
09-11-2013, 02:46 PM
on
Quote:
Originally Posted by
ihandy
If you want to order on online Glowshift sells the adapter only, but as posted above any tubing or hose shop should be able to hook you up
GSlahor
TIA.............
That is a good psi,, over 50 but under 70
09-11-2013, 02:54 PM
on
ihandy....check out ITP (think they're merged with MKM Customs/Sinister)...they have a nice line with a schrader valve.
GSlahor....I read a steady 65psi...sometime it sits at 67.
09-14-2013, 06:37 PM
on
I took the old plug left over from the blue spring upgrade drilled out the center then brazed on an air fitting so I could attach a hose with a guage to check the pressure worked great
johnarahill
01-24-2012 09:56 PM
gmc28
11-18-2010 08:09 AM
WMDPSD
08-30-2010 07:07 PM
ms1780
06-22-2009 04:36 PM
