Toyota Kit help!!! Please
I'm trying to install the toyota power steering kit from Mid fiftys in my 60 with a 223 engine. The problem is that it just doesnt fit. The shaft for the steering column comes out almost under the brake pedal when bolted up and there is no way I can get the clutch slave cylinder back on the trans. The old and new boxes seem to be the same size from the mounting flange to center of the gear box but It doent look like the slave will even go back on even if I get the gear box where it needs to be. Any help would be great and pictures of your set up if you can Thanks a bunch.
Perhaps you could do some of us a big favor, before sending the Mid Fiftys box back? Please take a couple pictures of the two boxes together, for comparison. Might just help some of us (like myself, who are thinking of going with the Toyota box) see the difference? I have an original Toyota box now, and plan for it to go in my 57, that has a 302 in it.
Thanks in advance.
Aloha, Tony
Thanks in advance.
Aloha, Tony
Thanks in advance.
Aloha, Tony
Thanks in advance.
Aloha, Tony
I think I understand what you are doing now. Am I right, that you want to use the stock steering column and connect it up to your new box? And the Toyota would not let you do that? I will have to do some playing with mine to see where it comes out. The stock column and box are still in my truck. (need it that way for now to be able to move the truck around.) It may be a while, but I will see what I can find. Please post pics of your CCP box installation, in as much detail as you can. Thanks.
Aloha, Tony
Aloha, Tony
Aloha, Tony
Aloha, Tony
CPP box... Perfect. Fit was awesome but I did have to grind down the shims a little to line up. No frame drilling. Hose fittings same a Toyota box. Used a recommended rag joint from CPP and it worked great too. Looks and works great. Aerostar pump makes a hum when under load but other than that all good. I used a horn saver kit from mid-fifty's and couldn't be happier with them for giving full credit when they got their Toyota box and brackets back from me. Mid-Fifty's is a stand up company. Happy Camper.
Right on, can we see some pictures? I may be interested for this conversion in future...
