9 rear end Disc Brakes
Been reading up on 9 rear disc brake conversions and am looking for opinions. Im installing a 9 rear axle in my 53 panel. The axle is missing backing plates, emergency brake cables, drums and everything associated with the brake shoes. If Ive got to replace all that Im thinking I could just as well convert to rear discs. Is there a bracket that can be bought and known rotors and calipers you can pick up at say Rock Auto to complete the conversion or is it better, in the long run, to buy a complete pre packaged kit? Im running 15 wheels on the panel and the fronts have already been converted to discs. I also have CPPs disc brake master and their 2/4 wheel disk brake proportioning valve. Im not going to race the ole Panel so I dont think I need Monster rotors or multiple piston calipers but I do want to keep (must) my emergency brake, even though its got a automatic transmission.
Any thoughts, recommendations, things to look out for, etc? Thanks in advance!
Received 4,132 Likes
on
Contact https://www.currieenterprises.com/ , they have everything 9". https://www.moserengineering.com/ is another place..
A word of caution on rear disc swaps. A lot of them use the old Cadillac Seville calipers with integrated parking brake and they are a nightmare to bleed and keep adjusted. I would recommend one of the kits from someone like wilwood that has the small parking brake drum and separate brake caliper.
nonrev321
17
04-04-2016 04:37 PM
TonyJestis
11-06-2012 01:36 PM
dslman1
01-08-2011 03:08 PM
