Hard to find correct 4x4?
Old 08-28-2013, 11:32 AM
drguitarum2005's Avatar
drguitarum2005
drguitarum2005 is offline
I'm in the market for an old F100 and for whatever reason, really want it to be 4x4...FACTORY. Are those hard to find in the 65-66 year range? I'm not opposed to the bumpsides either but IMO the ones before that look even better. I don't necessarily care that it's factory (read: I could do a conversion later myself), I just want to know it was done right...which is hard to tell from most sellers. Am I in search of a unicorn here?
Old 08-28-2013, 12:41 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
If you find a 61-66 F100 4wd excluding the 66 F100 4wd. You will have found pretty much the same truck. Same with the F250 4wd in all these years. I have found 2 of them one is a 65 F100 4wd that I found while looking for parts for my 63 F250 4wd. We do seem to have more than our share of them showing up up here in the pacific northwest part of the country. The holy grail of these would be either a F100 or F250 crewcab in a 4wd platform. Now those are rare. Good luck with your search.
Old 08-28-2013, 01:14 PM
drguitarum2005
Thanks for the info. What's the difference on the 66 versus the 61-65? I don't plan on doing hardcore rock crawling or anything but the occasional light off-road use. I do plan on either doing performance upgrades to the motor (if it's one that I like) or putting in a motor to get some speed out of the truck. Is a bumpside a better platform for that?
Old 08-28-2013, 07:09 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1966 F100 4WD's have coil spring front suspension, use the same cab as 1965/66 F100/250 2WD, use the same Styleside beds as 1964/66 F100/250 2WD
1961/65 F100/250 4WD, 1966 F250 4WD have front leaf springs, have a cab step visible when the doors are opened.
Use 1957/60 Styleside beds, called the 'wrong' beds when installed on 1961/66's, as the bed lines do not match up to the cab lines.
Old 08-28-2013, 09:26 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
On a recent trip down thru central Idaho on hwy 93, I bet I saw 15 slick 4x4's sitting in farm yards and for sale along the road. Didn't have time to stop and inquire, but thought it was odd to see so many....
Road trip anyone?
Old 08-28-2013, 11:43 PM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
They are surely rare around my area don't see them hardly ever for sale and when they are they usually are rusted bad. I have a 64 f100 4x4 and a 66 f250 crew cab 4x4 both factory I like the early 4x4 with the steps inside the door and the formation on the roofs
Also I believe the 66 cabs use the same floors and cab mounts as the bump sides so it would be easier to do a frame swap onto a 67-72 4x4 frame I like the 67 and newer 4x4 frames as they are easier to lift and correct the steering
Old 08-28-2013, 11:47 PM
drguitarum2005
Thanks for the info guys. How hard is it to replace the ignition harness on a 65? Would need to find one somehow...
Old 08-29-2013, 12:21 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
A quick glance in CL up here in Spokane and surrounding areas under cars and trucks for sale (search under f100) revealed 3 61-66 4wd trucks for sale that from description and pics appear to be factory 4wd trucks.
Old 08-29-2013, 12:27 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Road trip anyone?
Hey Tinman sounds like my drive down 93 would probably take longer than yours did. I usually try to stop and take pics if they are easy enough to get to. I might even do some door knocking if the farm dog doesn't look to viscous. Im going to google up hyw 93.
Old 08-29-2013, 10:19 PM
drguitarum2005
I know this isn't a 4x4 but for the right price, I don't have to have it. Can maybe add it later if I really find the need. What are y'all's opinions on this truck? Inside needs some restoration. He said few small rust holes in bed floor. Haven't seen in person yet. I do know it needs an ignition harness.
65 ford f100
Old 08-30-2013, 10:59 AM
NumberDummy
65 ford f100
You want a 4WD and now you're considering this vastly overpriced 2WD turd with a swapped 460 engine/trans from who knows what.
4,000 bucks and it needs an ignition harness (whatever that is)? IMO, 400 bucks is too much!
Old 08-30-2013, 11:20 AM
drguitarum2005
Exactly what I was looking for! I had already mentally written this one off. I gotta quit posting every consideration I have! When I get down to a real consideration ill post it. Thank you sir.
bigd0785
12-11-2018 01:18 PM
Curated Content Editor
02-10-2018 01:19 PM
Jamie4fam
03-09-2017 11:41 AM
Scottbmcd
05-24-2015 12:19 PM
1966Jacked4x4
06-08-2013 08:43 PM
Quick Reply: Hard to find correct 4x4?
