Clicking rear end
on
Could just be something broken in the brake system, pull the tire and drum off and have a look. If all that checks out jack up both rear wheels and put the axle on jack stands and with the trans in neutral rotate the tires to see if you can locate the source of the noise. If it's coming from the diff then pull the rear cover off and have a look, again it could just be a tab that has broken off a clutch disk and is jambed in somewhere it shouldn't be, not a big deal as long as it's cleared out of there, but it could also be something more serious and finding and fixing it now should be a lot cheaper than waiting for it to completely blow up.
derek0525
12-07-2012 09:19 PM
Fungus232
05-02-2012 11:18 PM
clevisR6
1983 - 2012 Ranger & B-Series
10-23-2005 01:02 PM
