Towing opinions wanted
2012 F150 Reg cab 6 1/2 " Bed, 3.7 engine and standard diff.
What does anyone think about my towing 4800 # TT with this rig.
Would of coarse have Load Leveling and anti sway.
I am not going to be going on real long trips, like I did with my 7.3 and fifth wheel.
Any opinions appreciated.
What does ye manual say for towing capacity? Go by that. But, off me old haid, I'd say for that weight, ye should be good. I've towed my 25' travel trailer all over the country with my '93 V6 Dakota, nary problems, it's rated to tow 5,200 pounds. Me trailer is 3,200 empty, but we load the rascal to the gills as they say. Main thing is stopping power. Be safe!
I really don't think you will have any problems towing a 4800lb. travel trailer with it. It is lacking a bit in torque compared to the other motors...but I don't think you will really feel it until you start heading up steep grades and it will then cause you to be in a lower gear and higher in the RPM range. Even then I don't think it will suffer all that much.
Don't know where round here is, but here in the Bluegrass, we have a fair amount of hills.
Thanks for the reply. All opinions appreciated.
I personally would not hesitate to haul your load requirement with a 3.7 V6. Eventhough it's a V6 that is one stout V6 for what it is. It is both more powerful in hp & tq than some of the top shelf V8 engines GM, Ford & Chrylser were putting out just a decade ago.
Not to mention the F-150 chassis is one of, if not is the best you can buy for towing/ hauling. Like I said, hook er up and take a pic for the thread. I don't think there is anything to worry about.
The only thing that I see would make worthy of further discussion is your rear axle ratio which wasn't mentioned. If I had the 3.7 and wanted to tow 5,000 or more I would want at least a 3.73 or 4.10 rear end if it was possible.
My 5.0L has the 3.55 which is great empty or around town. But with the loads I carry in some hilly areas I wish I had the 3.73 rear axle or 4.10 at times.
I am personally looking into changing out my rear axle set from 3.55 to 3.73 or 4.10? I want a stronger pulling truck from a dead stop with a load and mid-range when pulling a long grade. I love the 5.0 but its a motor that likes to rev, and I think the 3.55 ratio I have is holding me back.
*Edit* plus I think if I change out my axle ratio for a lower ratio it will hold me over for the next 4-5 years or till Ford works the teething years out of the 2015+ models.
Trailer I'm looking at is 6,XXX lbs dry. If I changed out from 3.55 to 3.73 with yhe 5.0 would I not notice any difference getting the load rolling from a stop on an incline, or mid range pull etc...
There might be some difference getting rolling but you might need delicate instruments to detect it.
I'm in Northern California, while we have pleanty of flat-land and valley, we also have some very challenging mountainous highway and back country & canyon roads.
