I'm needing to know if I can remove my oil pan off my 1990 F-250 460 without raising the engine from the frame, or in other words do I have enough clearance to remove the pan without excess stunt wrenching.
Any info would be appreciated.
I want to change oil pan gasket and rear main seal
NO. the engine has to be lifted out of the mounts AND the oil pump must be removed. Also the Y-pipe must be removed and the trans. Just pull the engine out, it will be SO much easier
Okay...thank you for that. I had a feeling it would be a real job, see what else I should do while it's out of there.
Kinda thinking a hot rod crate motor now
