Where to buy cleveland exhaust manifolds
Guys my 14 yr old son is building his first dent. It has a 351 cleveland and we need a left exhaust manifold. Where would be the best place to buy one or any cleveland parts for that matter?
Also are the Cleveland's as good an engine as I keep hearing they are?
Fyi the pickup is a 76 f250 2wd 3/4 ton, 4 speed. Started life with a 300 6 cylinder previous owner (original owner also) switched the engine in. no rust but pretty dinged up. My son is sanding it and painting it himself. He is a dent lover same as I am.
Thanks for any help.
The 351 Cleveland was a car engine .351M 400 engines were modified Cleveland design many parts inner change 'I'm thinking you could use exhaust manifolds off a 351M or 400. I would check it out .I'd check out a junk yard see if you could find a used one.From LMC truck they want 130 bucks for a 351M 400 one
if it has the stock intake on it, and it's a 2bbl carb it has 2v heads.
Also typically on the intake side of the head, on the corner you should see either a 2, 4 or m cast into it. pretty self explanatory as to what each one means. it's not 100% as not all had that casting but if it's there it will positively ID which type of head it is (you will never see a 2v head cast with a 4 there for example)
Look at the middle of the page here :
TMeyer, Inc. Precision Automotive Machining
351m/400 on top, 351 cleveland on bottom.
Notice the 351m and 400 have a raised portion around the distributor and thermostat.
D4AZ-9430-D .. 351C 2V Right Exhaust Manifold / Obsolete
D1ZZ-9431-A .. 351C 2V Left Exhaust Manifold / Obsolete
1970/73 Mustang/Cougar / 1970/74 LTD/Mercury Marquis/Torino/Montego/Ranchero / 1974 Cougar.
D7TZ-9430-A .. 351M/400 Right Exhaust Manifold / Obsolete
Applications: 1977/79 F100/350 / 1978/82 Bronco / 1980/82 Econoline & F150/350.
D5AZ-9431-A .. 351M/400 Left Exhaust Manifold / Obsolete
1975/76 Torino/Montego/Cougar / 1975/78 LTD/Mercury Grand Marquis / 1977/79 LTD II (not an LTD!)/Thunderbird/Ranchero/Cougar.
