I have an 89 4.9 300, I cant find a right way to do a flush on this year and cant find anything when i go under the passenger side, can someone please point me in the right direction as to from where i can drain the coolant from? I need to add a thermostat, thank you
Reason: different problem
Should be a valve that you turn on the radiator...usually on the same side as the radiator hoses and on the opposite side of the bottom radiator hose....other then that just pull the bottom radiator hose off and let it flow...
i accidentally broke the coolant sensor, the part that screws into the housing is REALLY stuck and i sadly dont have the right size to remove it, didnt budge with the wrench, im thinking about applying heat with a torch perhaps? any help?
And it looks like it is in the bottom on the drivers side. The picture is too small to really tell for sure.. But it is the biggest I could find on short notice. Here is a better shot:
thanks for providing exactly what i needed. I was able to locate what i think the drain plug is, it doesn't have the twist attachment so i think draining the hose at the other bottom end will work the same. Definitely a little part i will look out for next time I'm at the yard.
the thermostat replace went fine but after letting it run for a while i noticed it was still running cold, staying at the C mark steadily, should i check out the core now, maybe a clog? I thought this would regulate my temps..
**update**
after replacing thermostat I checked to see if heater core was clogged, it wasn't it had clean antifreeze inside, I still hosed it and clean water circulated out. Still running cold, idling around 750 rpm
The gauges on these trucks are known to be inaccurate. You may be trying to fix something that isn't broken.
yea that thought has been itching at me..the gauge does move past the cold mark and I could see it moving very slowly, wouldn't this mean that it works if it moves period, or can a broken gauge only go up to a certain point?
