attention to details are what makes a difference
well a few of mine, sorry lacking pics on some parts but ehh....
first, horns (the bracket after some sanding and soaking in CLR)
second tails and front lamps (originals were badly cracked and faded so they were replaced anyways with what I wanted), horns are working now again over looked usually...
also gave the truck a good bath, makes her look like new.
Put the tool box back on, which makes the truck have a younger more youthful look to it.
put a POW/MIA decal on my tail gate to show my support for those who are gone but not forgotton/armed forces
one I did a while ago, the battery, usually another item overlooked by most people...
another project I did a while back (and my favorite mod so far...) wood trim, still haven't put all the pieces in, and may not put them all in, mainly just wanted to replace the XLT trim pieces on the dash, other then that I am happy with it as is
and one final over looked item in general, the bulbs...I replaced almost every one so far, just have one or two others to deal with
I sanded em down to nearly bare metal and primer em and them high heat enameled them cause they get beat on by the sun...
...If you do paint your calipers make sure you tape off the notches where the caliper slides , and lube them good , don't want sticking calipers , pay attention to details ....
I just compressed the piston all the way into the caliper..
Bam no problem now..
.....I wasn't talking about the piston , its the slides that go into the V notch that holds the caliper on , you don't want to paint that , it needs to be paint free and lubed , the caliper moves at that point , don't know how you cleaned and sanded and primed and painted them with the brake line attached ??? must have been a bitch , lazy ??, i would have taken the line off and do the work on a bench , when i seen this thread about detail i was interested because i like detailed work , looks like just a couple cans of spray paint , sorry i was just disappointed .....
Sanded it right there on the truck.. Wasn't bad.. Primed them with a thin coat of high heat and then painted em..
Idk how much more someone could do with something like this.. Without buying new.. If your dissappointed post a pic of your front suspension.. And show if you've taken any time and though to touch it up..
You can look at my profile , never painted my calipers , but theres a lot of pics of the truck , won a ford truck show with it , and beat a lot of mustangs with it at the strip and on the road , just sold it a month ago for 7000. , wasn't really for sale , but i got what i wanted for a 18 year old truck ....
aysw6670
Ford Truck Parts for Sale
07-22-2016 02:37 PM
GreyFordFan
16
08-30-2003 06:46 AM
