anyone get Ziebart undercoating done?
I was wondering if anyone had ziebart done for undercoating and rustproofing? Im a rust freak I hate the smallest pot even on the axle or springs so Im looking to get the new truck done 110% with something that will last. I will annually spray fluid film before winter also to help with corrosion but im looking for any experience people have had with undercoating. Im located in the North East in New York State with lots of road salt and sand/salt mix on local roads.
The one near me handles a number of different aftermarket add-ons.
This topic can be equated to the great gas vs. diesel debate. Some people swear by rust proofing, some think it causes more problems (trapping water) than doing good.
My truck went right from the dealer over to Ziebart for the undercoating. I saw what happened to my 2000 after my first year here in Pittsburgh and I wasn't about to let that happen with my '11. With that said, the only rusted items on my truck right now (that I can see) are my Rancho 9000's and my driveshaft. Everything else has had a coating on it since "birth". They also recommend an annual maintenance of the initial application, which is like $35. Even if it's snake oil, it provides me with a sense of security that SOMETHING'S protecting my truck...
If you search the 6.7 forum, I think there's a thread in there about it as well.
Ziebart...Yes flat black coating. Annual free touch-ups were included in the initial purchase and are required to keep the warranty. Looks great smells like sheet. Tell them to make sure they cover up those pretty stainless Bilsteins or Ranchos or they will get hit with the black goo too. My 08 SD was used and didn't have any undercoating. It was starting to rust. I believe they should all have something on them from the factory at minimum something like LPS or Ospho or something to get down into the seams and bare unprotected metal. I have one of those electronic inhibitors on a 95 GC Jeep. Its just now starting to pop in all the usual places but its 18+ years old and driven in the salt belt. The sacrificial anode systems work well if installed properly. Bottom line is the guys who don't live in the salt belt will tell you its a waste of time. On the contrary if you do. Ever seen an under carriage after driving through snow, slush, salt? Very ugly! You guys in Arizona have no worries
As a side note. You or Ziebart need to pull the tail lights and soak the wheel well seam where the quarter meets the inner but pull the sponge like material out first. Nother nice design henry! And they've been at it since this box was designed....sponge in a wheel well really!
No rustproofing is 'forever', so a yearly inspection by you or them is a very good idea. Your truck will surely rust out without some kind of intervention on your part, based on where you live. Make sure that anything they apply stays soft and gooey.
I drilled 1" holes in my inner fenderwells in the box, so that I could shoot oil into the outer fenderwell lips where the dreaded "water/salt holding foam" is installed by Ford. I drowned that area in ATF, shot from a pump oil can. I couldn't find a good way to access that wheel lip area except by drilling hole, which I plugged with 1" plastic plugs from Ace Hardware.
I had a coating done on my 2007 new its more of a hard shell satin finish. What I di like about the hardshell is it holds no moisture like a paint finish. Slop just runs off, the hardshell finish allowed me to apply Fluid Film froma spray guy without impacting the adhesion. That's my big concern is I like the Fluid Film after the rustproofing, BUT once fluid film is applied there is no paint or a undercoating that will ever stick again. It will always fish eye.
That sponge in the box wheel well is still there? Can I pull it out with a hook and wire?
