Help with 5.8 performance upgrade
First time Post I have a 1994 F350 4X4 XL with 5.8 5spd Got the truck off my Pops he has babied the truck for 105000 miles, looking for some knowledge . Want to increase my hp & torque... Heads? cam? Headers? will stock fuel injection intake be fine or should I replace that as well. Thanks for any guidance you can give Paul
3-4k will get you lots of power.
392-427 stroker, heads, intake, cam, exhaust. If you do work yourself then great.
Stroker is optional but the other stuff is needed.
Plenty of knowledge already here in the forum, just gotta search.
First start with a good tuneup. Msd coil, good quality wires cap and rotor, fluid change and filter swap. All fluids and all filters... Synthetic if you can.
Long tube headers and high flow cats, and 3" exhaust. (Personally I'd do 4" diesel exhaust because its cheap and easy to find, and any back pressure you need will come from the headers and cats)
Heads and intake are a combo. 1.7 roller rockers will allow the current cam to be "acceptable" but I'd want more.
Before cam swap you should get a chip with programming software. Not an off the shelf chip, quarterhorse or tweecer is what you need. Then upgrade injectors to 30s and retune the truck.
Depending on money left over, I'd say cam swap, but personally I'd do a stroker kit with cam to match.
Fordenthusiasts
28
11-27-2012 06:06 PM
92f150powell
16
09-14-2012 09:11 AM
chevyassasin
07-10-2011 11:06 PM
currituckF150
15
05-24-2007 09:22 AM
calazo
05-28-2004 12:19 PM
