WHAT'S THE TRUE PERFORMANCE POTENTIAL OF A 3V V10?
Hi Guys, So here's the deal. I have a 2005 3V v10 complete (manifold to manifold), and the harnesses. I would like to eventually put this under the hood of a 85-01 Mustang or a 84-91 Lincoln Mark VII. Why? because I have it and it hasn't been done all that many times before. The plan calls for a TKO 6 speed, working cruise, ac, etc. Here's the big question: What is the max safe rpm/tq/hp that these offset crank engines will take reliably. Keep in mind I'm talking a 3-5,000 lb car here, not a 7,000 lb truck pulling a 9,000 lb trailer. I'd just hate to go through the work of creating a unique work of art and grenading the motor the 1st time it revs past 6500 rpm. Thanks in advance.
Good question. With four-bolt main caps and crossbolting, resulting in a "6-bolt main" motor, the bearings certainly won't be walking much.
But in terms of real results, we just don't know. At least I don't
The problem would be the balancing shaft, and whether or not that can run up to 6500 RPMs and tame the inherent vibration in a 90-degree V10.
doesn't the balance shaft spin at half speed?
diesel_dan
Modular V10 (6.8l)
23
03-18-2008 01:28 PM
