1990 f250 seats
I do not believe the 97 F150 seats are directly interchangeable with a 90 F250. You need to measure the floor mounting bolts front to back and side to side then measure the mounts on the 150 seat. although if you really light the seats you can always fabricate the mounting brackets as you need them. Just make sure you use quality metal for the brackets and that everything is nice and tight when finished. You don't want the seat coming apart if you have an accident.
