Welded on truck and not receiving fuel
Hi guys, I just bought a 1989 f-150 4x4 with the 4.9l inline6. The frame was cracked so I welded a plate to it...I managed not to disconnect the negative terminal on the battery when doing so and now my truck isn't getting enough fuel to run it. My pump makes a high pitched wine it never made before and it dies after idling for 30 seconds, and it will continue to whine until I start it. I cleaned all of the connections, EEC relay, and TPS connection. I can get pump the external pump for $30.00, that's not the problem I just want to make sure I'm not missing anything. I thought I could have fried the computer but I don't have any error codes and everything else's works fine.
Thanks.
Thanks.
Thanks.
Thanks.
Not saying it's the right thing to do, but I've welded on a couple of my trucks with the battery connected, key on, and radio blasting. Didn't hurt anything... the trick is to put your ground clamp RIGHT NEXT TO where you're stinger/gun is. I suppose if you were welding AC you *might* induce a stray current somewhere that a DC arc wouldn't, but some Jeep guys mount a second alternator (w/o regulator or rectifier) as a welding power source for trail repairs.
Ford apparently recommends that you disconnect all the electronic modules and the battery before welding. F*** that... I'll stick to DC and take my chances.
Alright, so I checked the EEC relay, it's got power and works. Check the computer, took it apart and none of the capacitors are blown, it works. Took the inline fuel pump (high pressure pump) out, hooked it up to a battery and it works fine.
Could it be the dual function resivor!? I don't know what the problem is, please help.
Thanks.
Thanks.
I think you need to check fuel pressure at the injector rail supply line. I'd also pull codes. I realize this is what everyone tells you to do, but there is a reason for that.
For info:
Your '89 truck has a low pressure pump in the tank. It feeds a reservoir. The reservoir is located on the driver side frame rail. The reservoir acts like a float bowl in a carb. Low pressure fuel fills the reservoir and recirculates back to the tank.
A second high pressure pump is located on the driver side frame rail ahead of the reservoir. It pulls fuel from the reservoir (the float bowl) and sends it to the fuel rail. From there it recirculates back to the reservoir.
These model dual tank trucks have a different reservoir than single tank trucks. The dual tank trunks have a reservoir with valves that route the fuel. When you switch from one tank to another you are selecting which low pressure fuel pump (in the tank) is powered. The dual reservoir has valves (mechanical) that route the fuel.
Single tank trucks have a much simpler reservoir. You can use a single tank reservoir on a dual tank truck to convert it to only one tank, and you should pick the front 19-gallon tank.
For info:
Thanks xl I really appreciate your knowledge. I would like to keep this as original as possible as I am the third owner, second owner was a good friend of mine. It was originally a farm truck, I'm attempting to revive this bad boy.
Do I need to split the line before or after the external fuel pump? Also how would I be able to check codes? I'm new to the mechanic side, I'm use to new vehicles, this is my first "project".
I'm too cheap to take it to a shop, I'm determined to try and figure this out with y'all's knowledge.
Thanks guys.
Thanks guys.
