6.2L V8 Discuss the 6.2L V8
Do you burn premium when towing?
Old 08-15-2013, 07:40 AM
22rimfire's Avatar
22rimfire
22rimfire is offline
This has probably been discussed before, but there might be some new owners that could chime in. I'll be towing the travel trailer for the first time this weekend (approx 7K lbs), and was wondering if the stock PCM recognizes and makes any adjustments for higher octane? Or is it just a waste of money? I'll expect to go through two tanks on this trip, and was thinking of burning reg on the first, and prem on the way home just to see if I noticed a diferance. No big hills on this trip, and we're heading to the coast so will be at or near sea level. Only 900 miles on truck so it's not even broke in yet. Anyway, your thoughts? Thanks, and I'll post up a trip report when I get back.
Old 08-15-2013, 07:47 AM
thomabb's Avatar
thomabb
thomabb is offline
Running a gas with higher octane rating than what the engine is designed for does nothing. Higher octane rating only means the fuel is more resistant to compression-detonation.
Now, if the "premium" fuel also has no ethanol in it, that is a different story. Some stations in some states still sell gas without ethanol as a selection at the pump, but it is getting harder to find.
Old 08-15-2013, 07:57 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
This is incorrect.
Running premium in the 6.2 will yield you more hp. This was confirmed by the 6.2 engineer back when he was around answering questions here on FTE.
Old 08-15-2013, 08:26 AM
thomabb's Avatar
thomabb
thomabb is offline
Running higher octane rated fuel than what the engine is designed for alone can not improve HP - it defies physics.
Now, if the "knock sensor" is sensing pre-ignition and retards the ignition timing to protect the engine, HP is reduced. I did not see the q&a with the 6.2 engineer, but maybe that was what he was referring to?
What is the minimum octane rating required for your truck? Does the manual specify different fuels for different conditions?
Old 08-15-2013, 08:48 AM
thomabb's Avatar
thomabb
thomabb is offline
"Octane is defined as a fuel's resistance to knocking. There is no benefit if the octane is higher than what the engine needs. Engine knock occurs when fuel in a combustion chamber ignites before it should. This disrupts the engine's operation. But electronic knock sensors are now common and have nearly eliminated engine disruption." - California Energy Commission Consumer Energy Center
All the research I read over the years on this subject reads almost exactly as this quote summarizes.
I will also throw out there that there is no tangible detriment to running higher octane fuel, other than to your wallet. So I can see why people choose to pay a little extra for the peace of mind.
Old 08-15-2013, 09:01 AM
thomabb's Avatar
thomabb
thomabb is offline
Old 08-15-2013, 09:10 AM
2000silverbullet
Old 08-15-2013, 10:03 AM
thomabb's Avatar
thomabb
thomabb is offline
Thanks for that link. So the octane rating recommendation for these motors is purposely understated so the knock sensor controls engine timing more frequently? I did not know manufacturers were doing this.
So does your manual suggest different fuels for different conditions? My newest gas motor is a '08, just curious.
Old 08-15-2013, 11:01 AM
22rimfire's Avatar
22rimfire
Thanks for the replies guys. So the Ford engineer says 10 HP gain. While that's nice, I'm not sure it's worth the extra .30 cents a gallon I have to pay around here for 91. I think I'll stick to the reg this weekend and see how it goes. When I tow in the mountains it might be worth trying though.
Old 08-15-2013, 11:04 AM
22rimfire's Avatar
22rimfire
I Don't remember seeing anything in mine (coulda missed it I'll check when I get home). I know the EcoBoost does.
Old 08-15-2013, 12:55 PM
rvpuller's Avatar
rvpuller
rvpuller is offline
I run E10 87 or 89, in some of the midwest states E10 is reg 87 with 10% ethanol added to makes it 89. Runs just fine on the lower octane is was designed, I see no need to run the higher priced octane gas.
Denny
Old 08-15-2013, 02:22 PM
2000silverbullet
I don't ever recall seeing anything where they recommended different grades of fuel for different conditions, but if you wanted a little extra hp, the option's there.
I'm running a 93 tune so I get more than a little extra hp. My tires are paying for it, already ready for another set before winter sets in.
Old 08-15-2013, 09:35 PM
BigMix's Avatar
BigMix
BigMix is offline
Try Premium Fuel without ethonal. I have tried premium but really couldn't see/feel the benefit. Of course I don't have a tune. Still trying to find a good station locally that has the straight stuff.
Old 08-15-2013, 11:59 PM
6.2gasser's Avatar
6.2gasser
6.2gasser is offline
I notice 1-2 mpg yield difference in the octanes. I put premium in frequently, less trips to the pump.
Old 08-16-2013, 07:55 AM
22rimfire's Avatar
22rimfire
Went ahead and filled up last night with 87. Pretty much everything around me has "up to 10%" ethanol. It was $102.31 when it clicked off at 3.79 a gallon. I think I was wrong about needing two tanks for our trip. It's only around 95 miles to the state park, so might make it on one tank if we don't run around too much. Leaving in a few hours and I'll be off the grid till Sunday night. Later
Quick Reply: Do you burn premium when towing?
