dual exhaust issues
dual exhaust issues
heres the deal i bought a couple thrush glasspacks, pipe and tips to put true dual exhaust on my 92 302 but no shop in town will bend the pipe for me, because the angles going to the manifolds are too steep. i was thinking about cutting the pipe after the y-pipe and then putting a thrush glasspack on, then adding another y-pipe and make a non true dual system but how do you think i should go about it? will it still be loud?
Talk to someone that knows what they are doing, because it sounds like your local shop techs do not. I have a 302 in my 4x4 with factory truck manifolds and there is PLENTY of room around my dual exhaust.
If you do decide to simply run a dual exit exhaust you won't get the exhaust note a true dual exhaust would give, but it should be similar in volume.
if it were me, I wouldn't be re-working the entire exhaust without adding long tubes.
furthermore, true duals are counterproductive in a street truck application. you will produce more low end torque with a y pipe application anyway, so if its easier to bail on the true dual idea now than it is to finish it, it will only be advantageous all across the board.
No single modification will remedy the pathetic performance of your 460. Head, cam, long tubes and is how you unleash a monster. Or a poweradder.
Well, if you have cats and want them gone, no shop will touch it. Might make up an excuse even... like "the angles are too steep". If you pull up to the shop and discover that your cats fell off on the way there however, they might work with you. Or you could run some hi-flow cats, which are way better than the factory ones.
Also, if you don't want a Y pipe you could run an X or H pipe. These promote scavenging, while letting you have true duals.
I'd get rid of the factory iron manifolds before I even considered messing with the rest of the exhaust.
And as mentioned above, if you just want to be loud, run straight off the factory manifolds into a 90 degree turndown. I bought my 460 truck like that... and you could hear that coming from miles away.
Y pipes promote scavenging from one bank to another. True duals are completely pointless (and net a loss in performance) until the y becomes a flow restriction, which with even 2.5" pipe would be too high of rpm to matter for a street truck. With a 3" or larger y, its a matter of "if" the y would ever become a restriction in the real world, vs "when", even in a drag application.
Thanks!
And as mentioned above, if you just want to be loud, run straight off the factory manifolds into a 90 degree turndown. I bought my 460 truck like that... and you could hear that coming from miles away.[/QUOTE]
i could do that but in town the cops would have my @$$ LOL, i'll consider risking that though
I'm tempted to just slap a 90* turndown right after the cat on mine... Not sure how obnoxious it would be though. I've heard that these cats are nearly mufflers in themselves? You might wanna try that first and save yourself some $$$
You keep saying you want it loud... Well then, chuck the mufflers in the trash, because loud = STRAIGHT PIPES
With mine, I might pick up a thrush welded or something before I hack the factory muffler off, just in case I need to put it on there.
I'd rather pull the cat, gut it, slip a pipe inside, and then put a catback system on, but not gonna happen at the moment
Putting "dual" glasspacks like your're planning wont get you what I want I don't think...
"I'm tempted to just slap a 90* turndown right after the cat on mine... Not sure how obnoxious it would be though. I've heard that these cats are nearly mufflers in themselves? You might wanna try that first and save yourself some $$$"
Island'r:
My 351W has about 3 ft. of 3 inch pipe after the cat, just enough to route exhaust out the side of the truck using a 90 degree bend, and it is not very loud at all.
Island'r:
