hood trouble
First, WD40 is NOT a lubricant! WD stands for Water Displacing not lubricating. Throw it away so you aren't tempted to use it for the wrong purpose or use it on your snow blower to displace the water to reduce rusting after the snow on it melts.
The hinges must be taken off to access the hidden pivot, free them up, and lube properly with some good lithium grease, NOT oil. Do an advance search on "hood hinges" and my user name, I have posted several times the proper method.
WD-40 Frequently Asked Questions
Water is a lubricant!
Posting a PDF.....place the pdf file somewhere online that you can create a link to....then post the link in your text here...for example
http://www.waynewaldrep.com/pictureh.../Magnum500.pdf
If I wanted to make it show up I'd just open the PDF and use "snipit" to create a jpg then post it as a jpg image. That may be the long way around but it will work. Good luck...hope this helps.
#29
#30
