Intercooler installation hardware
Ok... I've been doing alot of research installing an I/C, and my concern is making brackets for the I/C itself and the hood support mod. I see most fab their own brackets, and have welders, presses, etc. All I have is a drill, sawzall, and a BFH. Would buying the Banks kit w/o the I/C ($700.00, w/ brackets, pipes, boots, clamps etc.) solve the welding/fab issue? This is about $200 more than piecing everything else together individually. All I need then is a used 7.3L I/C and install. Thoughts?
I'm not sure what the banks brackets look like, but I doubt they'll work.. I made my brackets when I installed a stock 7.3 IC and then I had to modify those brackets slightly to fit an aftermarket 7.3 IC. Where are you located? The best thing to do is find someone who can make the brackets to fit your IC and core support..
As far as the modification to the hood latch support goes, I just cut the part that runs down to the bottom of the core support off and leave it off. Some people weld in a cut down piece of angle iron, but I've been running without that lower part on the support for about 5 or 6 years now and never had a problem from it. I'm fixing to do another one that way too.
Your other option is to use the remaining $200 to buy a decent mig welder that will let you fab the brackets and then you'll have another too in your collection!!!! I don't think you'll need anything amazing in a welder - harbor freight or Northern usually sells a decent little mig welder with mask and all. just another route to consider
That will work, but a good TIG will make a way nicer weld on aluminum than a spool gun if you know what you're doing. It's tough figuring out how to set up the TIG for aluminum when you're new to it though. LOL Don't put a sharp tip on the tungsten, IIRC we used tri mix gas, reverse polarity, and it really helps to have a TIG that you can adjust heat on the fly. We originally tried it with a TIG that piggybacked off another machine and it kinda sucked for aluminum.
