Lower Dash/Ash Tray Area Switch Panel
i know i see them before but was wondering if someone can tell me. its a replace meant panel with 2 gauge holes and 6 switches that replaces a section of the dash neat the ash tray. any one know what im referring too? i want to get for my ex my mechanic is hunting for me now.
big thanks my friends ill have to get it for Yuki when she arrives. Yuki is going to bee my exs name
Gauge 1: Oil Temp
Gauge 2: Trans Temp
Switch 1: Front Strobe (grille and bumper)
Switch 2: Rear Strobe (tail lights and lic plate bracket)
Switch 3: Left Alley (from the light bar)
Switch 4: Right Alley (from the light bar)
Switch 5: Takedown (steady work lights on)
Switch 6: Pursuit (flash pattern)
Switch 7: Front Driving Lights (mine didn't come with them standard)
Switch 8: Aux (currently powers the inverter)
Switch 9: Rear Tow Lights (under the bumper)
This setup was installed when I had an older style Whelen halogen light bar:
I've since upgraded to an LED with it's own controller:
I'll probably replace switches 3-6 with other duties:
Winch in/out
2nd battery isolate on/off
Rock lights
Fender LEDs
For an average rig, your imagination is the limit...maybe you want an inverter, maybe not...maybe some additional fogs on a custom bumper or push bar...maybe some lights to help hook up your trailer at night or you want manual power control over a rear camera or a separate power control over an aux fuse box...it's really whatever you can think up. As I'm typing this I just thought up to use one as a door light relay cutoff so I can leave the doors open without having the interior lights drain...
One suggestion for anyone buying one of these though...think big. If you have RiffRaff or whoever make you a setup with say 3 switches and you run out, you'll have hard time getting a 'factory' look when you have to go back in and cut more space...sometimes the switch mount plates aren't expandable, etc.
I took the thought that even if I don't use all 9 right now, over time I probably will, so why spend $ on a 6 switch mount plate and end up throwing that out to get a 9 switch plate later and have to sink the time into cutting, sanding, etc.
If you have the $ up front, I'd suggest you think big and get more than you think you'll need...what's the worst that will happen, you'll have some 'dead' switches on your dash.
A note on RiffRaff - they ROCK, but know that you'll have to send them the cover plate to your cup holder so they can color match your paint...so be prepared to have a hole in your dash for a couple of weeks while they match everything up. Well worth it to get your panel to match the dash spot-on!
Small ARB compressor
Large ARB compressor
Front bumper flood lights
Front bumper off road lights
Rear Bumper flood
Rock lights
Rear airbag control
Front ARB locker
Rear ARB locker
That is fairly extreme, though. If you make your own switch panel you can get 9 switches on there.
Two other switches are on the flat area on the left side of the F650 dash under a digital dual air guage. Those are for the Blue sea ACR battery switch, and a switch that operates a 500 amp cutoff solenoid for the winch.
All Lighted CarlingSwitches in different colors to delineate what type (lights, winch, lockers, Battery)
The wiring can get rather hectic with all that stuff, though.
Since I do not have power rear windows, I did procure, but not install a set of OEM DPST switches to fit the cutouts (plugged from factory) in the overhead console to be used in the future to operate roof lights if I ever decide to install some. Most of the ones you find are momentary to operate the windows, but I think these came from a 1990's Lincoln.
Gads, that would make a total of 13 switches!
Kinda glad I did go with the nine, but I do think that engraving looks sweet...
